Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 08-17-2009, 11:31 PM
Default LPE 200 Help...
Hello all..I have an LPE 200 800Mhz with the full keypad and have a few questions about it..Now I am familiar with the MOT stuff,plus its easy to look up model numbers and Flash options but this Harris stuff(Who the heck is Harris BTW..) I am not sure of. Basically I would like to program it to monitor a Half Analog,Half pro voice system.Would this be possible if I give more specific information like the model number,or is it unknown until the information is read and obtained? Is there a system key like a MOT system? Thanks for the help all,I have always been curious about the EDACS systems...:-)
Old 08-18-2009, 01:19 PM
davidbond21's Avatar
Send a message via ICQ to davidbond21
Well first check to make sure your LPE is capable of ProVoice. It has to have 1meg of Flash memory, the DSP must be flashed for ProVoice, and you must have option 29 installed. Press Menu("M") and scroll down to REVISION, then press Menu again and use the arrow buttons to scroll to "FLSH SIZ" which should read "1M" and also to "DSP RAM" which should display something similar to "i4r05g01"(maybe someone can chime in what the earliest flash is that will work, but my radio says 1999 which I think is the earliest year you could get an IMBE chip in these radios). Next, return to the main Menu, and scroll down to the bottom to where it says FEATURES, hit Menu again, and then scroll to end with the arrow keys until you start seeing two digit numbers listed like "04 05 06 07..." and look for "29" as this is the ProVoice option. (Also, just as a note, check out what other options your radio has installed here.)
It's no problem at all to listen to both analog and ProVoice talkgroups on the same EDACS system. During programming, all you have to do is set each digital talkgroup as such, otherwise by default it is set to analog. That's most of the work right there.
There is no system key like Motorola uses for programming radios up on EDACS, unless you happen to live in one of those unfortunate places(like I do) that uses ESK. This will prevent you from programming a radio onto their system without a)some extremely expensive equipment and b)the correct Key. Otherwise it's pretty straightforward (read:easy) to program an EDACS radio to monitor without it trying to affiliate with any sites.
Edit: I just checked the database for New Jersey, and didn't see any ESK in use on any of the EDACS systems, so you're probably golden.
(+)-3-methoxy-17-methyl-(9α,13α,14α)-morphinan
BC350C, IC-R7000, PRO-95, PRO-96, PRO-197, PSR-500
FT-7800R, Racal 25's, LPE-200's, Jaguar 725M
Old 08-19-2009, 03:50 AM
Thank you for the informative reply.I will check into those options and see what I have.If an option or two is not installed is that easy to put in or does it require the depot to do so? Thank you much.. :-)
Old 08-20-2009, 11:10 PM
I checked the flash size and it says 512k..Darn,oh well.Thanks for the information...
Similar Threads
WTB LPE 200 w/o Provoice OttawaBob Old Classifieds Archives 0 08-03-2009 10:27 AM
LPE 200 copain Harris / MA/COM / GE / Ericsson Forum 0 07-01-2009 01:45 AM
Pending issue - LUCAS OIL STADIUM dfoutch Indiana Radio Discussion Forum 8 06-26-2008 07:53 AM
WTB LPE 200 Charger Muxlow Old Classifieds Archives 2 03-04-2008 09:57 AM
programming system in LPE 200 scanamateur Harris / MA/COM / GE / Ericsson Forum 2 01-10-2007 12:26 AM
