Originally Posted by cahighwayman25
I have an 800Mhz GE MDX radio, that when I went to program it with a couple of freq's, it's now stuck in program mode, and I can't get the radio to work normally. Please help me. I tried to wirte the old codeplug back, but the PC isn't seeing the radio.
Trevor KI6KGN
If your MDX powers up in the program mode without a program cable attached, or buttons held, I suggest the following:
1. Remove the front cover and keycaps.
2. Remove the rubber pad that contacts the pc board.
3. Make sure that the pc board is clean and nothing has collected in the area of where the rubber pads contact the pc board.
4. Power up the radio without the rubber pad and see if the radio powers up in the program mode. If it doesn't, clean the rubber pad with soap and water, dry very well and return it to the radio to test. I have had the rubber pad cause this problem several times.
5. If the radio still powers up in the program mode without the rubber pad in place, you can use another good radio to test with. Take the display board from the good radio and test in the bad radio. You should be able narrow down where the problem is without too much trouble.
** Make shure the radio is unplugged from power cable before working with boards etc.
Good Luck
