So lets see if i got this rite
Connect all 37 pins from the male to the female?
1-1
2-2 amd so on on the DB37?
And then connect pin 8-25 and 6-20 on both DB37's?
And only 3 wires go into the DB9 from the 37?
Then jump the other 2 pins and that that?
Whats the most simple way to connect the 37's to each other. Would be a pain to connect wires to each pin to pin. Would it be possible to connect them direct and not use any wire for the DB37's? Other then the 4 jumpers and connect them to the DB9?
A picture im sure would help me out. Ill see it and then be like wow... im dumb
I tried to make a cable last night from my front mount cable, figured just copy that pin out to 2 DB37's and then to then DB9.. but failed
