Actually a data base probably would not help, and I am not sure would exactaly be legal. The "encryption" part of feature encryption refers to the fact that it's keyed to the ROM serial number and radio code files, that's why a feature string from one radio won't work in another, usually that is. Changing the numbers in your feature string won't work either, most of the time. When you update they need the radio code version (the .bin file), the dsp version, the feature string, and the ROM serial number, especially in the newer radios like Jags, everything has to match to update the features correctly. There are some people out there that contend they have successfully hacked the codes, like the LPE's you see on eBay with every feature enabled and 65565 talkgroups available but display a "DSP ERROR" the first time they try to listen to a ProVoice system. Lots of times those are running on some type of evaluation/development radio code that slipped out of the factory.
