Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 11-03-2012, 3:02 AM
Muxlow's Avatar
Send a message via Yahoo to Muxlow
Default M7100 Orion Convert
I have a remote mount orion radio, and a front mount M7100. How can i make the M7100 into a remote mount with the orion cables? Or how do i put the orion head on the M7100?
Back of the M7100 has a smaller DB cable then the Orions 37 pin one, same with the ribbon cable for the control head. The M7100 is 2 "pins" smaller then the orion so not sure how this is done. But i know it can be done
Muxlow
..Yeah iv got some radios
Old 11-03-2012, 1:30 PM
Radioman96p71's Avatar
Send a message via Yahoo to Radioman96p71
Well, to make the M7100 remote mounted, just take the head off and put the blank plate back in its place. The cables will work just the same.
To mount the Orion head on the M7100 you will need the new ribbon cable that has the contacts on one end and the plug to go to the logic board on the other.
A M7100 can be a drop-in replacement for an Orion remote mount. The pinouts are exactly the same. The M7100 front mount kits are different tho, with the main difference being the ribbon cable going from the logic board to the back of the control head.
NØMB
Adam K
Polk County, Iowa
Old 11-03-2012, 4:03 PM
Muxlow's Avatar
Here are some pictures to help.
2470 Is the Orion Control head and remote mount bracket
2474 Is the Orion control board and the faceplate of the M7100
2476 Is the Orion remote cable and the rear of the M7100
So from these i dont see how these will just fit at all Unless i rig up my own cable to connect from the orion to the m7100 to make it a remote setup
And guess i would need that convert thing for the faceplates. Even if i cant get the orion system control head onto the M7100 thats ok. I can deal witht eh scan M7100 head as a remote. Just anyway i can make the front into a remote is all i want really..
Muxlow
Old 11-03-2012, 6:28 PM
Are you sure "2476" is a M7100? What the tag say for model?
Tim
Old 11-03-2012, 7:04 PM
Muxlow's Avatar
Yep. Top is the M7100 bottom is the orion cable
Tags
Harris Corp
Model MAMW-SDMXX
Ser #
IC
FCC ID OWDTR-0051-E
Cage 1PNR4
RU144750-061 RevQ
M7300/M5300
There is my problem lol
One of them things.. i KNOW its a m7300 but keep calling it a M71.. FML
Muxlow
Old 11-03-2012, 10:59 PM
Ah well then disregard everything i said, it doesnt apply to you haha.
NØMB
Adam K
Polk County, Iowa
Old 11-03-2012, 11:07 PM
Muxlow's Avatar
Yeah no wonder these cables arnt working.. Im like WTF these guys talking about!
Then oh.. there is my problem.. haha
So i assume the orion cables wont work on the 7300's
Muxlow
Old 11-04-2012, 1:03 AM
Nope, those are apples to oranges different. Control heads arent even in the same ballpark. Unfortunately you will need to aquire new accessories.
NØMB
Adam K
Polk County, Iowa
Old 11-04-2012, 2:42 AM
At least programming wont require a new cable, the DB-9 above the 44 pin is your programming port.
Old 11-04-2012, 3:04 AM
Muxlow's Avatar
Well im glad i spent almost 100 bucks on getting this orion haha
Not a damn thing i can use it for either.. Ahh.. Details
Ill guess its $$$ costly to get a remote kit for this M7300?
Muxlow
