J725M vs M7100 sensitivity
mitaux8030
Silent Key
Home
Comparing a Jaguar 725M to a M7100 on 800 MHz, it seems like the M7100 is a little deaf. The J725M has a 'noise floor' reading of -138dBm, compared to the M7100 of -129dBm (both terminated with 50 ohm load), and the M7100 has a corresponding 9dB less sensitivity compared to the J725M. And for that matter, an Orion, 700p, LPE200 etc.
Has anyone else made this observation? I guess there's precious little that can be done about it, since the M7100 front end and IF strip have absolutely no tuning points, physical or software.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
That number, -138 dBm, seems awfully low. I've NEVER yet seen any mobile or portable radio that had anywhere near that kind of sensitivity.
I've seen -131 on a particularly sensitive VHF XTS5000, but even at that level we're talking about only .06 microvolts. Which is amazing for a non-satellite product.
Are you sure that the 725 is really showing a receiver sensitivity of -138 dBm, on frequency?
I'd suggest rechecking that and inserting a narrowly tuned bandpass filter between the signal generator and the radio. I think it's got to be opening up on a spur or harmonic coming from an outside source or your generator's LO.
What kind of generator are you using to perform the test?
I can take my R&S generators down to -140 but at that level, RF leakage from inside the unit's case is stronger than the RF port's output. While I could pad down the output a few hundred more dB if I wanted to, by stacking attenuators, it wouldn't do a bit of good if the receiver under test is hearing the signal leaking through the chassis.
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
What are you using to indicate your RSI?.. The built in RSI on the radio? or are you using some sort of quieting / Sinad set up?
mitaux8030
Silent Key
Home
That -138dBm figure for the J725M & -129dBm for the M7100 isn't an actual noise floor measurement, it's the radios own FCC menu display under 50-ohm terminated, no input signal condition. Note that the difference between -138 and -129 dBm is 9dBm.
Then each was put across a HP 8924 to determine 12dB SINAD figures, and the J725M was 9dBm better than the M7100; 20dBQ findings were the same too. 9dB more sensitive and 9dB difference in FCC menu RSSI with no input signal - coincidental? Other 800/900MHz units here also turn in broadly comparable sensitivity figures, generally being a decent margin more sensitive than the M7100.
Its those findings that leads to the question: is the M7100 is inherently a little deaf?
dcr_inc
Delta, Pa
No it is not deaf, Your's apparently needs a hearing aid..
