Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 04-23-2013, 3:43 AM
Default J725M vs M7100 sensitivity
Comparing a Jaguar 725M to a M7100 on 800 MHz, it seems like the M7100 is a little deaf. The J725M has a 'noise floor' reading of -138dBm, compared to the M7100 of -129dBm (both terminated with 50 ohm load), and the M7100 has a corresponding 9dB less sensitivity compared to the J725M. And for that matter, an Orion, 700p, LPE200 etc.
Has anyone else made this observation? I guess there's precious little that can be done about it, since the M7100 front end and IF strip have absolutely no tuning points, physical or software.
Old 04-30-2013, 3:33 PM
That number, -138 dBm, seems awfully low. I've NEVER yet seen any mobile or portable radio that had anywhere near that kind of sensitivity.
I've seen -131 on a particularly sensitive VHF XTS5000, but even at that level we're talking about only .06 microvolts. Which is amazing for a non-satellite product.
Are you sure that the 725 is really showing a receiver sensitivity of -138 dBm, on frequency?
I'd suggest rechecking that and inserting a narrowly tuned bandpass filter between the signal generator and the radio. I think it's got to be opening up on a spur or harmonic coming from an outside source or your generator's LO.
What kind of generator are you using to perform the test?
I can take my R&S generators down to -140 but at that level, RF leakage from inside the unit's case is stronger than the RF port's output. While I could pad down the output a few hundred more dB if I wanted to, by stacking attenuators, it wouldn't do a bit of good if the receiver under test is hearing the signal leaking through the chassis.
Old 04-30-2013, 3:59 PM
dcr_inc's Avatar
What are you using to indicate your RSI?.. The built in RSI on the radio? or are you using some sort of quieting / Sinad set up?
PRO668, HP 1, WS1080, PSR800, PSR600, PSR500, PRO2096 (2), PRO106, BCD 296D P25 card, Commercial FCC license, Ham General, FAA Private Pilot, Business Owner, APCO Certified Tech.
Old 05-01-2013, 5:13 PM
That -138dBm figure for the J725M & -129dBm for the M7100 isn't an actual noise floor measurement, it's the radios own FCC menu display under 50-ohm terminated, no input signal condition. Note that the difference between -138 and -129 dBm is 9dBm.
Then each was put across a HP 8924 to determine 12dB SINAD figures, and the J725M was 9dBm better than the M7100; 20dBQ findings were the same too. 9dB more sensitive and 9dB difference in FCC menu RSSI with no input signal - coincidental? Other 800/900MHz units here also turn in broadly comparable sensitivity figures, generally being a decent margin more sensitive than the M7100.
Its those findings that leads to the question: is the M7100 is inherently a little deaf?
Old 05-02-2013, 8:23 PM
dcr_inc's Avatar
No it is not deaf, Your's apparently needs a hearing aid..
