P5400 No Power
Muxlow
Super Secret
Middlesex County
Ello ello
Iv got a Macom P5400 radio.
I have about 5 batteries and all hold charge and no problems with them.
The radio however will not power up.
Is there a fuse or spot on the board i can check to see if that has been blown or what not or anythign on the boards them self to have a peek at to see if there is a issue there or not?
When i power it up nothing happens on the screen and no sounds when i push buttons either
greenthumb
Colorado DB Administrator
If you hook it up to a power supply that can tell you how much current is being drawn, do you see any current being drawn when you power it up? If so, how does the current change over time?
Muxlow
Super Secret
Middlesex County
I took a peek inside the case and connected the battery and used my Fluke 1520 MegOhMeter on the board where it connects to the battery. Its showing 8V on the 2 outside pins and 7 on the center
LMR_Dude
F401, is the fuse you are talking about. Looking your picture it is between the two battery contacts on the right. It is horizontal and near TP 202 (which is the battery monitor point). I suspect that the left side of fuse is the load side so check for voltage there.
Happy hunting.
Muxlow
Super Secret
Middlesex County
Here is a little better shot. Im not seeing any of these numbers on the board.
If youd be so kind to circle them?
Iv checked the first horizontal fuse to the left of the battery pin and it had voltage. The next fuse that is vertical was fine too, the larger vertical one i got no reading
Were these the correct ones to check?
LMR_Dude
I've circled F401. The other components nearest it are a coil, cap and a diode. Just check F401 and leave them be.
That circle, left and low, as viewed from your second picture is TP 202, the test point for measuring voltage FROM the battery. If you have 7.5 VDC there then your battery and battery contacts are good. If you have 7.5 VDC on the OTHER side of F401 then you have more digging to do.
LMR_Dude
Check for voltage on the other side of F401 now by placing your probe on the contact pad of the diode to the right of the fuse. Its larger so you have a better chance of making solid contact and not damaging F401.
Ive also circled TP203, BATT GND, these points will give you solid contact.
Muxlow
Super Secret
Middlesex County
When i connect my meter to the left contact pin from the battery and the otherside to the F401 i get a reading of 8 from both sides
LMR_Dude
Try chassis grnd for the neg probe just to be certain.
You can also try this now that you have ID's both sides of F401.
WARNING: REMOVE THE BATTERY
Set the meter to measure continuity and verify if the fuse is blown. One probe to TP 202 and the other to the diode. This test is not the greatest since the fuse is still in circuit but infinite ohms is a indication of a blown fuse while something close to zero generally indicates a good fuse. Checking components in circuit is tricky so that why I went with you looking for volts first.
LMR_Dude
I don't understand "buzz". Your meters indication of continuity?
With one probe on TP202 and the other on the diode, what does you meter read in ohms?
