Orion and Handheld controller
TOP2
FREDERICKSBURG VA
I have a Handheld controller attached to an Orion D29MTX. It's working fine however I need to increase the contrast a bit. I have G47xxx radio code installed in the radio. However I can not adjust the contrast. It was told to me that the Orion has limited support for the HHC. I've tried it on the M7100 and I can adjust the contrast so I know it will adjust. I've programmed the HHC to display the menu for contrast but I can't double click on it to make any adjustments.
My question is according to everything I've seen this HHC will work on the Orion, has anyone managed to figure out how to increase the contrast? The backlight works fine
rescue161
KE4FHH
Hubert, NC
I know it's not the same, but Astro Sabers had to be opened up and there was a small pot to adjust the contrast. It may be worth checking into, then if it is too much on the M7100, you can modify it via the software.
Doink
Just because you can put an item in the menu doesn't mean the radio supports it and from the way you describe it, it sounds like the radio doesn't. It's been a while but I thought that if you dig through the Programmer help file, doesn't it say which programmable options are supported by which radios?
And no, there is no mechanical pot to adjust inside.
