Harris P25 Phase II Trunksysem From EDACS
TexScan780D
My local government is going to a Harris P25 Phase II trunk-system from an EDACS system, but the new system is not activated yet which I think will have 2 main sites and some simulcast sites.
Will the new system have to have total new talk-groups or used the same talk-groups the EDACS has?
How will the XG-75 and XG-25 radios change over to the P25 system since the radios are already in the field?
Can anyone tell me what the VIDA platforms means and the the digital trunked technology XG75.
thank you!
DisasterGuy
Maryland Shore
VIDA is like saying ASTRO, simply a branding for network infrastructure. There is no answer as to how the migration would be done since there are MANY ways it could be done. The most logical way for most migrations is to mirror the existing system and use a migration gateway to have both systems operating side by side. As for the existing radios, they are likely programmed for bith systems.
LMR_Dude
- It depend, the old TGs could be recreated on the new system or not. There's no requirement that all the EDACS TGs be brought forward into the P25 system. The systems engineer could use the migration as an opportunity to clean house of un/under used TGs or even introduce new TGs.
- You will see new TG numbers however, P25 TGs are assigned an Agency so you will see two numbers in front old TG numbers or totally new TGs. Depends on how much *** pain the engineers and techs want to experience.
-Most likely they will have both system programmed into them. This allows portables to be issued ahead of the P25 system being brought online and also provides a fallback in case of problems (and there are almost ALWAYS problems.
