Harris radios and programming inquiry
johnls7424
Somewhere in NJ
Harris radios that have ProFile installed on its software. Do you still need ProGrammer or Radio Personality Manager installed to setup talkgroups on the radio(s) or can you simply using the full keypad ( models) input the info on the radio and use it??
DisasterGuy
Maryland Shore
ProFile is simply OTAP and has nothing to do with keypad programming. The XG-100p allows an authorized user to modify conventional frequencies but not trunked personalities.
You need RPM to program and that requires a license. To use ProFile you need to have the radio enabled to accept it and the ProFile software setup on a mobile connected to the ProFile radio.
