Harris Master III GStar Identifiers
Emporia, KS
This is my first post. I have basic knowledge of my system, but I'm not a tech.
We have a Harris Master III repeater, and mainly Kenwood subscriber units (mine is a TK-3180 portable). We use GStar for the radio identifiers. It causes an audible data burst at the end of each transmission. It is quite annoying and loud, and some officers say it is the reason they don't use ear buds. Our local radio shop says that there is nothing they can do...with the radio identifier, the burst has to be there. The only option is either before or after the transmission.
I came from a Motorola 800 trunked radio system, and we didn't hear the data bursts, even though they were there.
Is this a fact with the Harris Master III? Can anyone point me in the right direction to correct this if possible?
Thanks,
gesucks
Our Nation's capitol
This has nothing to do with the Master III. It has to do with the Kenwood radios. The DOS feature (data operated squelch) is in the subscribers. If they do not support that feature, there is no way to not hear the ID. You can look in to using MDC1200 instead
Radioman96p71
You could look at setting the GSTAR ID to send after the STE is sent (or the Kenwood equivalent) that way the ID would be sent after the tone is reversed and dropped, essentially muting the audio on the repeater just before the ID fires. Only caveat would be if the system requires the ID to be on the output of the repeater, then you don't have a choice.
systech456
Set the GESTAR to the beginning of the transmission, instead of at the end.
Have the radio shop MSEDIT the M3 to perform a timed mute of the repeat audio at the beginning of each field transmission. In the systems I work with we mute for ~600ms at the start of each field transmission, this results in nearly perfect audio without the annoying squawks. The downside is a radio without ID turned on will clip the first 600ms.
A second option is to get a Cimmaron Model CPLUS 1,2, or 3 decoder.
This decoder can be set to provide a logic output while it is decoding GESTAR signalling packets, this output can be fed into the M3 and by programming can be set to mute the repeat audio path while this input is active. This would allow you to keep the trailing ID's, this also will not clip a radio without ID.
Good luck!!
ramal121
Lots and lots of watts
Calif Whine Country
The Kenwood radios indeed do not have "data operated squelch" such that Motorola has, but they do the receive mute thing at the begining of a transmission for an adjustable time. As systech456 said, put the data at the beginning and use the timed mute either in the repeater or the radios. Crank the time back until it just covers the data burst. This is probably you're best bet.
riveter
MD
I do love that GE-STAR screech sound.. miss it.
/offtopic
