WA SCAN
MECS_1947
Honolulu, HI
My 700p has the WA scan feature and does scan when unable to lock onto a CC, but it only seems to lock on to one freq set and not on any of the other freq sets, depending on the area I'm in. I have the correct freq sets and site #'s as well because by non scanning radio's work on the other sets. Any help is greatly appreciated.
Radioman96p71
There are several places to check to make sure that ProScan is enabled and configured correctly. Assuming you are using ProGrammer:
Check under ProScan/ProSound options that your values match the defaults. (click inside one of the boxes and hit F1 to see a window with default values)
Check under System Scan Options to see that ProScan/ProSound is selected and not Wide Area.
In the EDACS configuration for each system, the ProScan dropdown should be Dynamic if the sites are advertising their peers (most networked systems do this) otherwise you will have to select Fixed. If Fixed is selected, add the sites you want to be polled to the "systems being scanned" list on the lower left side. If this list is empty, it will default to not searching unless CC is lost.
Hope that helps
