Squelch problem on MA/COM M7100 VHF
nucleaireqc
Hello everyone, I have a problem with my squelch! traking in my data I have the OPEN and CLOSE squelch squelch, how can not hear the closed repeater?
Here are some pictures that should be the right configuration
tank you
nucleaireqc
They told me that the <open squelch> should be above 75 and therefore <close squelch> must be 25 (example)
DisasterGuy
Maryland Shore
I cant speak for the relative values but this is generally performed as part of a routine alignment and tracking data generally shouldnt be messed with except on a bench as part of an alignment. For squelch operation you would inject a signal at the desired level (typically around -120) and adjust the tracking data to obtain the desired result. It is hard to manipulate the values without the proper service equipment to make the adjustments.
