how to get the information for a scanner from a macom p7100ip.
rick2013
Fort Riley, KS
i have the p7100ip from macom and a bcd996xt scanner and was wondering what information i needed from the radio and how to get it from the radio to put it in the scanner. we are using the p25 system. any information will be helpful.
W8RMH
Feed Provider Since 2012
Grove City, OH (A Bearcat not a Buckeye)
The easiest way would be to locate the system on either the RadioReference or FCC databases. You will need the control channel(s) and talk groups. Is this a government or private system?
If you are referring to the Fort Riley (P25) System all talkgroups on that system are encrypted which means you can not listen to it on any scanner.
*Update* I just looked at your previous posts and your same question received the same answer back in January.
