Try using ProGrammer 18, use the "save radio code to file" and "save DSP to file" option to read out the firmware in the newer radio and save it to disk. This feature doesn't exist in ProGrammer 19 or 20, they removed it. (Jerks!) But 18 will work.
I can't remember if RPM has a similar feature or not.
If it's not in the main program, it's in the radio maintenance tools.
I can't remember if this trick (programmer 18) works on radios programmed with RPM only compatible code versions.
If all else fails, you can get your local Harris dealer, or, as a last resort, the Harris TAC to send you the original versions of the radio code and DSP that are in your new radios, so you can use it to upgrade your fleet.
Or, as the final option, maybe someone here might help you out? Guessing.
It is HIGHLY recommended that you run all your radios at the latest available firmware and DSP releases, although it does take a bit of time to do the upgrades.
Your upgrades, from R15 to R18, and F7 to F9, are a BIG jump in level so you really need to do the upgrades on each radio.
It would be a very good idea to take that opportunity to back up each radio's feature encryption and tracking data to disk as well. just in case you have any issues with any of those radios. Once every so often, you'll have to recover a radio after a glitch in the upgrade process turns it into a brick.
