Jaguar 725M quick help
praxidike
Hi all,
I need some quick help in determining what cables are needed for a project. I have a Jaguar 725M remote mount and a ol' VHF Orion I want to put together with the handheld controller. I've looked high and low for information but want to connect both radios to one controller. My question is which option/remote cables do I need for this?
I understand an external speaker will be needed. I have that already. Thanks in advance. If anything, the 725 will suffice for now.
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
Two radios to one control head or HHC:
1-The J725m must be the MASTER RADIO. (Ditto with M7100 & Orion pairings)
2-The Orion must be a 512k logic radio, and be configured as the SLAVE RADIO.
3-Most any firmware will work fine in the J725m.
4-The Orion needs to have Group 45 (or later) firmware in it to function correctly. (I humbly recommend OG47402.BIZ).
5-For dual-radio, you will need a 19B802554P10 cable to network the two radios together.
I hope this helps.
