10-95
- Joined
- Dec 19, 2002
- Messages
- 1
So I have a batch of nice Harris P25 AES DES P5100's heading my way. It's been a while since I have played with the Harris M/A Com stuff. I know in the days I worked with MPA's and MRK'S swapping RF decks and reprogramming was all I needed to do to change bandsplist. So I read here that the radios are no longer two pieces consisting of the RF portion and the Logic controller portion?? Is this correct? I was under the impression that changing out the RF deck to a preferred range and reprogramming and re-alignment was all that is needed. is this not the case on the 7100/5100'S?? If not , I will write and SC4 file and see if I can pull it into the ham portion of UHF anyway.
