Hi.
I have a MRK radio from Macom. It use in edacs trunking system but i have a two problems.
First, and the main problem is in transmit signal. I can normal receive calls and it works fine, but if i try transmit (press PTT) then my signal is very low (radio is in HI mode).
Second problem is in model number. I have radio model ZGT (Z mean - this model works on 800MHz) but my edacs run on 440-470MHz. So the radio must be converted to 470. That's possible?
Maybe if this is possible, my anntenna is from 800mhz and it's not good working on 470mhz.
