I've had erratic ProVoice receive issues with my M5300 mobile radio for some time now.
I had to get off my lazy backside and program up a P7100 (also with ProVoice) to verify this.
Occasionally, ProVoice transmissions come across that are clear to the P7100 and are just random noises
on the M5300.
The P7100 proves that the garbled transmissios are in fact ProVoice and not encrypted.
The weird thing is, once this happens, the M5300 won't properly decode ProVoice transmissions on that
talkgroup for quite some time. And then it'll work fine with ProVoice for a while.
It's pretty random except that when the problem crops up, it tends to stay in that state for a while.
Although my antenna installation is "stealth" rather than "high performance", it's good enough. Signal strength readings via the FCC menu are plenty good enough. So I don't have any reason to believe that
the problem has any bearing on signal strength.
Got any ideas?
on the M5300.
Got any ideas?
