Aegis
mancow
N.E. Kansas
CVSD (Continuously Variable Slope Delta) modulation.
It can be implemented with or without encryption.
It's basically the GE / Ericsson / M/A-Com / Tyco (whatever they are this week) version of what Motorola calls Securenet.
N
N_Jay
Guest
I am very sure AEGIS was not CVSD, seems it was one of the early DVSI vocoders.
Now you have me curious. :roll: :confused: :lol:
EDIT: OK, did some looking.
It was generally called MBE.
It might have been DVSI (or a predecessor to DVSI), or something somewhat proprietary.
It used GSMK like ProVoice.
Voice Guard was an earlier product that competed with early Securnet.
Aegis competed with early Astro.
tbski100
Central NY
I reference to AEGIS:
Does it have to be turned on in a talkgroup all the time, or can it be used only when wanted, possibly using a option key to toggle it on and off? Can it be used for I-Calls?
Forts
Mentor
Ontario, Canada
I don't believe AEGIS can be toggled on and off... remember AEGIS is a voice modulation, not an encryption scheme. For them to switch between AEGIS and clear (analog) voice on the same talkgroup, I would imagine they would have to have the same talkgroup programmed in twice... Once using AEGIS, ones using analog. I can't see this being very practical or useful though. And yes AEGIS can be used on I-Calls. A police department local to me uses AEGIS extensively on all their communications, with the exception of a provincial common analog inter-agency channel.
mancow
N.E. Kansas
I found a neat paper describing EDACS and it give a bit of an explanation as to how it all works.
I was thinking that Voice Guard was unencrypted and the encrypted version of it was just called Aegis but now I realize that it's actually another format in between Voice Guard and Pro-Voice.
I thought (Voice Vuard which I thought Aegis too) was just their version of Securenet but it's GFSK. Interesting......
I wonder how the audio quality differs between Voice Guard and Aegis?
http://hamradio.arc.nasa.gov/EDACS_Whitepaper.pdf
2.12 Aegis Digital Voice
Encrypted Aegis digital voice provides a totally secure
communications system even against the most sophisticated
eavesdroppers.
In EDACS Aegis digital voice communications, analog voice is
converted into digital signals prior to transmission, using digital
vocoder technology.
Aegis digital voice is transmitted using GFSK digital modulation over
working channels at 9.6kbit/s, which is the same transmission rate as
that of the control channel. This uniform design provides every
EDACS radio base station with the inherent capability for supporting
Aegis, as well as clear voice and data.
Aegis provides an additional level of security because ordinary
scanners cannot decode it. It also offers a uniform digital
communications solution. In multi-site systems, the digital signal is
maintained throughout the transmission route and decoding is only
performed in the radio units or at the dispatch center. This end-toend
digital transmission design makes EDACS ideally suited to digital
voice encryption.
Muxlow
Super Secret
Middlesex County
I have 2 MRK's one is 800mhz and the other is a vhf. Also have a orion aegis. I have to program my freqs in twice if i want one for digital unencrypted voice and one in the clear. No way to turn it on or off.
But if you are listning on either channels and the other radio transmitts aegis you will hear the digital sound on the one chan, and the decoded voice on the other programed for aegis. And if you transmitt on the "clear" channel you will hear the voice call on both channels.
We haw:)
RayAir
I know it's old but AEGIS uses AME ( Adaptive Multiband Encoding) . 9600 bits per second digital coding speed.
Forts
Mentor
Ontario, Canada
For its age and the technology at the time, I always thought Aegis sounded pretty decent.
Sent from my Nexus 7 using Tapatalk
RayAir
Company literature states AME vocoder has 8 bands in the 0-2900 Hz audio range and bit allocation is directly proportional to the energy at the instant of the audio sampling.
I have some M/A Com MRK 2's that have one analog channel and one DES encrypted AEGIS channel.
Encrypted AEGIS sounds (to me), a bit better than the old Motorola Securenet. Securenet sounds scratchy.
I wish my radios had a clear AEGIS channel so I could compare the audio quality between the two ( clear AEGIS and enc. AEGIS).AEGIS being digital I don't think you would get the degradation like you do with old Securenet radios.
Another nice feature is that DSD cannot decode clear AEGIS. Use encrypted AEGIS and you are safe from everyone but the Big G.
Radioman96p71
Encrypted AEGIS is the same quality as DES/VGS. They all use the same vocoder it's just the way they encrypted the bits that is different.
Same modulation as ProVoice (even uses the same sync bits for the most part). No error correction tho and the weak signal "pops" can be deafening at times.
RayAir
DES vs. VGE
Does anyone know which algorithm would be considered stronger, DES or VGE?
My guess is DES because old GE literature seemed to state DES was restricted for export and VGE was exportable with a license in their time.
However I read that in addition to a 64 bit VGE key, customers can also add a 64 bit word (CUE- Customer Unique Encryption) so that even if someone had your crypto key they still could not monitor a VGE coded message unless they also had the CUE.
Radioman96p71
I know that VGE+CUE data is technically a longer KEY than DES, but I can't speak for its actual cryptographic strength. If i were to throw out a wild guess, I would say that VGE is some flavor of DES that has been tweaked a little to make it less secure to get around the export restrictions.
It would be interesting to see the actual analysis and compare their operation but VGE is proprietary and not subject to peer review like DES.
RayAir
That's what I was thinking. The algorithm couldn't be analyzed by any academic community,etc so who knows how secure it is.
There's a lot of VGE equipped radios on eBay.
