M/A Com P7100ip
K5TYN01
Pikeville, Tn
I'm sure this question has been asked a thousand times but what is the chances of programming a M/A Com P7100ip to Non-Affiliate with a P25 Trunk system that has a BEE00 OR BEE09? Without a system key.
Radioman96p71
If you are on RPM R10, you can program any P25-T systems aside from:
Code:
BEE07:
40F    ARMER
BEE00:
1BD    Louisiana LWIN
1A7    Texas TXWARN
348    Ohio MARCS
2A5    Tennessee TACN
188    Arkansas AWIN
BEE09:
13E Texas/Austin GATRRS
K5TYN01
Pikeville, Tn
Where would I go to get that done on mine? I just want to monitor. No transmit whatsoever. I know it states Phase II but the majority of talk Groups in my area are still using Phase I modulation. Any help would greatly be appreciated.
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
To program TACN without having the correct AAC System Key, requires RPM R08 or earlier (which includes Radio Programmer 17c through R20c).
And for any Phase-2 comms, requires RPM R10b07 or later!
Hopefully some computer savvy user out there will figure out how to disable the ACC requirement in RPM.
CanesFan95
FL
So a P7100 can do P25 trunking with Phase II? How do you get the older software versions? If the radio has already been programmed with a newer version, will the older version still work?
kb4cvn
Silent Key
P7100 only does Phase-1
P7200 and later does Phase-1 and Phase-2.
The earliest revision of software that supports Phase-2 is RPM R10b07, for any model of radio which supports the mode.
