Apparently so ...
From this MA/COM website ...
http://www.opensky.com/network/index.asp
From this white pager ...
http://www.co.tompkins.ny.us/pubinfo/pscs/options.pdf
So basically, OpenSky is a private LMR version of CDPD that does voice and data.
-rick
A fully integrated IP voice and data controller, based on CDPD architecture. As the heart of the OpenSky® network, it administers frequency re-use and automatic hand-off through the OpenSky® IP packet-switched backbone.
OpenSky is a wireless data solution developed by AMP originally for Federal Express use for its urban operations. Federal Express required a new wireless mobile data system that would provide four times the message data of its previous system. In addition, Federal Express also needed occasional voice communications to handle exceptions that would not be conveyed over the data system.
A partnering with Federal Express allowed AMP to develop a wireless data and wide-area
network solution that is reviewed here. Most systems deployed today are voice systems that support data, whereas OpenSky is a wireless data system based on data communications technology. The system currently supports public-safety 800-MHz channels and cellular AMPS channels16. The Commonwealth of Pennsylvania is currently deploying a statewide OpenSky system.
OpenSky is an 800-MHz system that utilizes TDMA with two time slots to support both voice
and data services. The two time slots can be used for both voice and data simultaneously or can be aggregated to support 19.2-kbps throughput on a 25-kHz channel. The two time slots can be split to enable full duplex voice operation or can provide a single simplex digital voice channel and a single data channel with 9.6-kbps data throughput.
What is interesting about this for Tompkins County is that, under a hybrid network scenario, the urban agencies, which may have higher data needs, could use OpenSky radios for data. This would take some of the load off the voice system and increase capacity. Also OpenSky could be used where some of the carriers have Cellular Digital Packet Data (CDPD) channels on their network.
-rick
