Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 05-19-2017, 1:12 PM
Question Buzzing sound, P7100IP
https://drive.google.com/open?id=0B5...ExoaV9FM1pkTG8
Anyone can tell me the cause for this buzzing?
Does the radio needs alignment?
Repairing?
Programming change?
Thanks.
Old 05-21-2017, 7:44 PM
Programming change. Is it P25T? If so, make sure it is set for narrowband, especially if you are using an older version of Programmer or RPM
Sent from my SM-G955U using Tapatalk
Old 05-21-2017, 8:49 PM
I have someone else doing the programming for me. It has worked flawlessly before, only until recently been getting the sound. The only thing that has changed in the system, is the control channel. Not sure if this could be the cause for the buzzing?
Old 05-21-2017, 9:25 PM
Originally Posted by WA3GPC View Post
Is it P25T?
Yes and yes.
Old Today, 8:59 PM
It usually happens when the signal is weak that happens to my radio occasionally
