Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 05-26-2017, 4:31 PM
Default Squelch setting
Does the squelch setting have any implication/bearing on P25 conventional channels if the signal is digital?
Old 05-28-2017, 7:09 PM
Scratchin' my head over this one...
FT-2900R, FT-101EE, HTX-202, IIC-2AT, BTX-121, UV-5R, KT-7900D
Old 05-29-2017, 9:12 AM
Not really. Basically squelch on a digital channel follows an AND rule. Signal must be present AND it must match all required data constraints (system, group, and unit ID) before the radio must unmute, so I don't think that it makes much difference except that if squelch is set too tight, it can reduce effective sensitivity and receiver range.
Adjust squelch for proper operation on that frequency in analog, and when you switch to digital it'll be fine.
No, I will not program your radio for you. No, I will not give you any software. Don't ask unless you want a rude answer.
Old 05-30-2017, 7:17 PM
I've noticed that the receiver will sometimes stay unsquelched if the squelch setting is too low on certain analog channels,but I wasn't sure if raising the squelch adjustment level much higher, to eliminate the issue, would affect the sensitivity on digital receive.
