Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
  #21 (permalink)
Old 08-11-2017, 12:39 PM
DisasterGuy's Avatar
What is the model of radio. We have seen some of our newest radios that are featured for both EDACS and P25 not actually show EDACS in the feature menu even though it is there. Perhaps there could be a simular issue with yours.
Sent from my SM-G900V using Tapatalk
  #22 (permalink)
Old 08-12-2017, 7:57 AM
I've also been told that P25T needs to be enabled in any radio for Phase2 to work,in the same way P25C is required to be enabled with P25T.
  #23 (permalink)
Old 08-12-2017, 10:40 AM
M5300. I had it in my last car but haven't figured out a satisfactory way (yet) to hide the front control head in the car so that it's accessible but not visible so it's currently in a box waiting for me to solve that problem.
I know that the P25 phase 1 trunking option is something like 1100 dollars. Which is just retarded.
I'm also curious as to whether or not the M5300 needs hardware added to it to enable the GPS functionality. Or if it's just a feature upgrade only.
No, I will not program your radio for you. No, I will not give you any software. Don't ask unless you want a rude answer.
  #24 (permalink)
Old 08-12-2017, 10:42 AM
I'm pretty sure the 5300 requires a board for GPS. If it has the board there will be an SMA connector for the GPS antenna.
  #25 (permalink)
Old 08-14-2017, 8:51 AM
The GPS connector is present on the back of the radio. I've never opened the chassis to see if there are any option boards in it. I prefer to leave working radios alone.
  #26 (permalink)
Old 08-14-2017, 10:31 AM
Radioman96p71's Avatar
If you have the SMA connector then you have GPS. It's not used for anything but OpenSky but you can tap into the NMEA stream from the accessory connector.
N0MB
Adam K
Polk County, Iowa
  #27 (permalink)
Old 08-14-2017, 7:41 PM
And that is what I would like to do. GPS based signal strength logging. Record both GPS data and RSSI information and plot coverage maps.
  #28 (permalink)
Old 08-15-2017, 12:24 PM
kb4cvn's Avatar
Location: Nowhere near a paved road, in the Blue Ridge Mountains of Virginia.
Default M5300 GPS Board & Info
Yes, there is an optional GPS board required, and it requires some Feature Encryption too.
  #29 (permalink)
Old 08-15-2017, 12:26 PM
kb4cvn's Avatar
Default GPS Receiver Field Upgrade Kit Manual
The manual is too large for RR to allow an upload (2 Meg file size).
If you need it, PM me.
