Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 06-07-2018, 8:21 AM
KG5HHS's Avatar
Default M7100 unit ID scan
Hello All,
I have looked in the help files, but donít really know where to. When Iím scanning a P25 channel, the unit ID shows. Is there a way to shut it off so I know what channel is being received vs. what unit it talking?
John Longoria
KG5HHS
Old 06-07-2018, 8:37 AM
DisasterGuy's Avatar
I haven't been in RPM 1 in a while however look for Display Options. You can set it to be system line or group line if I recall and also specify toggle behavior of the display.
Sent from my Pixel using Tapatalk
Old 06-07-2018, 12:23 PM
KG5HHS's Avatar
I’m using programmer, when I go into display setting the only things I can adjust are the backlight and the group line display, but when I select any one of them, it says it will truncate to 7 character (6 characters if I select the dash option).
John Longoria
KG5HHS
Old 06-07-2018, 12:39 PM
kb4cvn's Avatar
Location: Nowhere near a paved road, away from the maddening world.
Post
Nope, part of the radio's design protocol to display the transmitting Unit's ID (either raw LID number, or aliased Alpha-Numeric name tag) in EDACS trunking, and P-25 conventional & trunking formats.
The last radios I remember allowing you to disable UNIT ID display were the: MDR, MDX, PCS, Allegra, XPE, EMP,EMM, TNP M-PA, FMD, (Alpha) FMD, M-PA, all of which were EDACS-1 & EDACS-2 era radios.
This image is from the HELP SCREEN page in Radio Programmer....
Old 06-09-2018, 3:55 PM
KG5HHS's Avatar
That's what I was afraid of. I also noticed that while displaying the unit id in the top line, the bottom line shows "1" Which is what I have set for P25 Group Set (P25 Group Set: P25 CONV/ Group Name: 1 / Group ID: 1) Would it be possible to set these per channel so I can tell at least what channel it is?
Example:
Group Name: Channel 1/ Group ID: 1 - For Channel 1
Group Name: Channel 2/ Group ID: 1 - For Channel 2
John Longoria
KG5HHS
Old 06-10-2018, 12:50 PM
kb4cvn's Avatar
Example:
Yes. I always scan displaying channel name.
Check your personal e-mail. I just sent you a PDF on another issue.
Send me the personality file, and I will tweak it for you...
Old 06-11-2018, 1:31 PM
kb4cvn's Avatar
Post
After seeing John's personality file, the solution was simple.
For channel not group display on P-25 Conventional, change the DISPLAY setting from Group to Channel.
