Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
  #21 (permalink)
Old 08-02-2018, 2:56 PM
I can probably find key cap kits here in our shop, if you have trouble finding them contact me and we can make a deal.
  #22 (permalink)
Old 08-03-2018, 3:16 AM
AD0TY, I sure will. I appreciate it.
So my first Orions came in today. Didn't have time to play with them before work so I rushed home all giddy and got to it.
First impression: Tank. Built like a brick out house. I like it. Size is similar to the Motorola MCS2000 only it feels way better built.
Mine are dirty. Both from service and storage. The control heads are filthy, a pet peev of mine. I dove right in and disassembled the first control head. Wow. They built them right. The JRC components were a pleasant surprise.
After carefully disassembling the head I gave it the general good scrub. Buttons cleaned up great, the head cleaned up great. Hell everything cleaned up great. Gave the boards a quick brush of D5 and called it good. I'll finish them up this weekend.
Couple questions: Has anyone removed the blue display lens without destroying it? Mine could stand a good polishing. Lots of swirls.
Does anyone have a list of the buttons or what the abbreviations refer to? Some of them I'm familiar with, some I have no clue.
Visit my local club online!
http://w5cuq.com/
  #23 (permalink)
Old 08-10-2018, 7:28 PM
Ok, after a little break I'm back on these GE radios.
Trying to get the radio and computer to communicate. I am using a RF guys cable.
Radio and cable and control head are hooked up. I turn the radio on and it reads " PC PROG" on the display.
I open ProGrammer and click read, it indicates "Error reading or writing serial port"
Comport settings are all correct.
Any suggestions?
http://w5cuq.com/
  #24 (permalink)
Old 08-10-2018, 9:33 PM
jparks29's Avatar
Double check your port settings.
What operating system? I found 10 messes a lot of stuff up.
The only good cat is a stir-fried cat!
  #25 (permalink)
Old 08-10-2018, 9:52 PM
That's the odd thing. The computer I use for windows based radio stuff is an old slow-ish XP machine. I think it may be the RF guys cable, unless the previous department did something to inhibit reading/writing to the radios.
Comport is set to 1 in programmer, my COM1 port is a true serial port and settings are as follows:
BPS: 9600
DATA BITS: 8
PARITY: NONE
STOP BITS: 1
FLOW CONTROL: NONE
FIFO BUFFERS are at default.
Are the Orions sensitive to COM port speed like some of the older Midland gear?
http://w5cuq.com/
  #26 (permalink)
Old 08-11-2018, 2:15 AM
jparks29's Avatar
bump it up to 115200
  #27 (permalink)
Old 08-11-2018, 2:33 AM
That got it! I would have never guess to go that high on the BPS. I do appreciate it.
Unfortunately, I get "radio was programmed with a later version of radio Programmer software."
Is there a way to roll these back or will I have to track down a later version? I'm using R18B02.
http://w5cuq.com/
  #28 (permalink)
Old 08-11-2018, 3:25 AM
jparks29's Avatar
PM me a way I can contact you, Ie FB, and I'll walk you through it.
Can't discuss software here.
  #29 (permalink)
Old 08-11-2018, 12:07 PM
Ok will do. Thanks.
Sent from my SM-G930R4 using Tapatalk
http://w5cuq.com/
