Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 08-27-2018, 7:24 PM
KG5HHS's Avatar
Default M7100 Transmit/Scan issue
Hello Everyone,
I have a very odd problem. I have a VHF P25 M7100. I programmed a simplex channel with a DCS tone but it will not receive that channel and it will not transmit on that channel if the radio is in scan mode. I found this to be very odd. I have tested this by transmitting and receiving on many radio's. I can receive and transmit fine as long as the radio is not in scan mode. Does anyone know how to fix this?
John Longoria
KG5HHS
Old 08-28-2018, 8:47 PM
kb4cvn's Avatar
Location: Nowhere near a paved road, away from the maddening world.
Question
Originally Posted by KG5HHS View Post
Hello Everyone,
In the Conventional Frequency Set:
Is the channel in the Scan List?
Under SCAN OPTIONS:
Is ALWAYS SCAN SELECTED CHANNEL enabled?
Is SCAN WITH CHANNEL GUARD enabled?
Old 08-28-2018, 9:07 PM
KG5HHS's Avatar
Yes, scan is selected for this channel in the conventional frequency set. Also under the Scan Options, "always scan selected channel" and "Scan with channel guard" are selected.
John Longoria
KG5HHS
Old 08-29-2018, 12:46 PM
kb4cvn's Avatar
Question
OK, thanks.
  • What software and revision used to program the radio?
  • Did you read the radio, edit the file, and program it back in?
  • What revision of flashcode? (the J2R file)
  • What revision of DSP code?
Hopefully I can help...
Old 09-03-2018, 3:55 PM
KG5HHS's Avatar
Im using Programmer R18B02
I usually just edit the file, save it and write it to the radio.
Revision is J2R11C02
DSP code I think is F8R06N05
John Longoria
KG5HHS
Old 09-06-2018, 9:50 AM
jparks29's Avatar
Under scan options, make sure Transmit Select is on Selected and NOT Scanned...
The only good cat is a stir-fried cat!
Old 09-13-2018, 4:05 PM
KG5HHS's Avatar
I just checked, in Scan Options > Universal Scan Options >Transmit Select I have "Selected".
John Longoria
KG5HHS
