Help! .BIN & .DSP files needed!
rmiles
I've got a few radios here that have corrupted files that need to be restored, and a few that just flat out have the wrong code loaded. I lost many of my back-up files due to a recent hard drive failure. If anyone has a copy of the following, I'd surely appreciate getting them. I'd rather have .BIZ if there's a choice, but at this point I’ll be happy to take what I can get. Thanks in advance!
S1R05E05.BIN
M2G46402.BIN
M2G33300.BIN
I4R05K01.DSP
G4R06C04.DSP
ADI02000
ADI01100
WCRadioGuy
Salisbury, MD
S1R05E05.BIN
M2G46402.BIN
M2G33300.BIN
I4R05K01.DSP
G4R06C04.DSP
ADI02000
ADI01100
I have,
S1R05E05
M2G46402
M2G30200 and 400
I4R05K01
G4R06D09
Both ADI's
PM me for email
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
I have:
J1R01C08.BIN
J2P02A32.BIN
J2P02A36.BIN
J2P02A45.BIN
J2P03A06.BIN
J2P05A29.BIN
J2P05A31.BIN
J2R03B01.BIN
J2R04A04.BIN
J2R07A05.BIN
J2R08A05.BIN
J2R08B01.BIN
J2R09A05.BIN
J2R09B02.BIN
J2R09C01.BIN
J2R10A05.BIN
OG33300.BIN
P1R14A00.BIN
R0p07a01.bin
R0r06a00.bin
R0r08b02.bin
S1D01A08.BIN
S1R01C12.BIN
S1R05B02.BIN
s1r04c04.biz
S1R05B02.BIZ
F4R06C05.DSP
F4R06D09.dsp
F6R04A04.dsp
F7R03A01.dsp
G1P01B26.dsp
G1P01B40.dsp
g4p02a05.dsp
G4R02A01.dsp
G4R06C04.DSP
G6P05A30.dsp
G6P05A31.dsp
G6R01D01.dsp
G6R06C04.dsp
G6R06D09.dsp
i4r05d01.dsp
i4r05f01.dsp
i4r05g01.dsp
i4r05h01.dsp
i6r06b01.dsp
But I think you already have those. :)
Elroy
ElroyJetson
What is the difference between a .biz and a .bin file, anyway?
And if anyone knows...my highest J version code is J2R10A05. What's the minimum
version of programmer that this code will work with?
I think that code supports P25 trunking, given that it came from a P25 trunking radio.
What I think this forum could really use is a matrix that shows what all these different codes do and support, and what
radios they work with.
Elroy
JungleJim
A .bin file is straight radio code and a .biz is a compressed form. The .bin you see could have come straight from Macom or it could have been read out of a radio and contain errors. No way to tell. The .biz are straight from Macom and as such are far less likely to contain errors and should be used over the .bin. The code inside for any given version is identical.
Programmer 18B supports the P25 trunking. Technically you would need R19A to access any new options in that code, however you can use earlier versions to program the radio just fine. The personalities in the radio and files on your hard drive are not backwards compatible among the generations of Programmer. For example a personality written in R20 cannot be read or opened with R19 or earlier. To determine what version of Programmer your radio was programmed with look in the Revision menu under PRS VER or PERS VER (depending on radio/flash) take that number and subtract 14. Programmer R20 shows a PRS VER of 34.00, R19 would be 33 and so on. RPM version 1 starts at 50 and RPM R2 is 51.
When new options or capabilities are added they are incorporated in a new flash code. It seems that more flash codes are released to correct operational issues though.
ElroyJetson
Is there a way to force a given dsp file into the radio even though the software thinks it's incompatible?
Case in point...F7R03A01.dsp, and a "40 option" radio. The radio code is J2R10A05.BIN.
Currently, that radio has G6R06C04 DSP in it.
How can I force the software to put the F7 DSP into the radio? It thinks it's not compatible,
but ALL the options are turned on in the radio so by all accounts it should take most ANY
revision that is intended for a 7100.
Can I do it just by changing the name of the file to something beginning with?
Like R7R03A01.dsp?
Elroy
JungleJim
If you have an I&Q P7100 you must use the G series DSP codes. As such those early version radios cannot do P25 trunked. There are physical differences in the radio as well as the code and they have to line up or the radio won't work.
ericom
Hello. i need help for recovery lpe-200 scan,
i dont have bin and dsp files
tank you eric
