Tracking Data Problem
I have three radios I cannot read tracking data from. The first is a 403-400 MHz KPC-400 (KRD 103 111/18 R1F), The second is a 136-155 MHz Panther 500P (KRD 103 150/6 R1C), The third is a 150.760 - 174 MHz Panther 500P (KRD 103 150/2). I have an OEM TQ3370 RIB with power supplied, and I'm using an OEM RPM 113 2472/1 R1A (TQ3382) programming cable.
I'm using RadioMaint ver R18B02 to attempt to read the data. I get the same error message upon data acquisition; "Could not read Tracking Data". When I click on "Read Tracking Data from Radio", the program completes "Handshaking", but when it begins "Reading Tracking Data" I get the error message.
I tried reading the KPC as a 500P and vice-versa, which yields a wrong radio type message. I've also tried it without power to the TQ3370, and get the same "Could not read Tracking Data" error message. I also verified the output of the OEM power supply (manufactured by Black Box Corp) to the TQ3370 at a nominal 16.4 VDC. I am able to read tracking data, using the same setup from several other M/A-Com radio models (i.e., M-RK's, LPE-200's, 700P, P5100 series).
So, based on that information, does anyone have any idea why I can't read the tracking data?
"I have not eaten enought of the tree of knowledge, though in my profession I am obliged to feed on it regularly." - Albert Einstein
