Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Hawaii Radio Discussion Forum
Hawaii Radio Discussion Forum Forum for discussing Radio Information in the State of Hawaii.
Old 09-19-2008, 02:43 PM
Exclamation Kauai County Public Safety --CHANGED??
Does anyone know the latest news on the Police and Fire systems????
I'm unable to pickup any one any more. I tried to search it using channel stalker but no luck..
PLEASE any help would be greatly appreciated!!!
Mahalo,
MAX
Old 09-23-2008, 01:58 PM
trooperdude's Avatar
If you can't hear them they most likely re-banded their 860 freqs down 15mhz.
Do you still hear a control channel on the 868mhz frequencies ?
Looking at their license i see a lot of 806mhz/823mhz channels licensed for mobiles and 821/853mhz channels
licensed for base.
http://www.firesafecouncil.org/
Be Fire Safe California !
Old 09-30-2008, 04:56 AM
Thanks for the reply,
I hear nothing now except maybe a click once and a while. or at least I think its a click as the scanner will stop for a second on a police channel then move on. I have just ordered a digital scanner so I'll be finding out real soon if they moved.
I'll keep everyone following this thread posted..
Thanks again,
MAX
Old 09-30-2008, 05:19 AM
Wiki Admin
Max, you might also check the Radio Monitoring Hawaii Yahoo group (as mentioned in a past message) to see if there's more information.
You don't need a digital trunker just because Kauai might have moved. If it was previously an EDACS system, simply subtract 15 mhz from the old frequencies and start looking. 73 Mike
Old 10-01-2008, 06:24 AM
Wouldn't a search have found the new feqs? I have a RS PRO-97 and have been searching the 800 mhz for the them.
Thanks,
MAX
Old 10-01-2008, 08:41 PM
Wiki Admin
Possibly. I doubt that they would reallocate their system wholesale, however. Do the math; if none of the adjusted freqs have a really horrible sounding data stream on them, you can assume that Kauai has not yet rebanded.
On second thought - didn't I read somewhere that they were moving from a LTR system to a P25? If they weren't on 800 before, save yourself some grief - use the FCC search tools in the database. Again, far simpler than just doing random searches
73 Mike
Old 11-12-2008, 01:32 PM
Well it seems that as of 11/9/2008, the Pro-96/Pro-2096 scanner will work, how it will work is beyond me, I'm waiting for RADIO AH7E HAWAII to release a "downloadable file so that you can program your radio hassle-free". More info can be found here -> http://www.qsl.net/ah7e/kctrunk.html
MAX
Old 11-12-2008, 02:02 PM
JoeyC's Avatar
When I went to Kaua'i earlier this year, I had programmed my trusty PSR500 up with the local TRS (Motorola) with the talkgroups in a VFolder. So I thought. When I got there I realized that I had NOT stored the system in the VFolder afterall. Being the small island that it is, I set the scanner in search mode to cover the 800 mhz band. I found 2 control channels. One I never got a talkgroup hit on the entire time I was there, and the other was the missing TRS that I had thought I programmed. I programmed the system as a TSYS into the scanner and within a couple minutes I was up and running. Since there were only 4 or 5 talkgroups used, programming them in after searching a while was no problem at all.
Old 11-12-2008, 07:15 PM
Well,
I have a PRO 2096 now and programmed it using WIN96 and downloading the channels from within the program using radioreference.com but I was unable to pick up any anything. Do you know of a place where there I can find info on how to program the scanner thats simple to understand? I understand what talk groups are but have no idea what TSYS or TRS is....
Mahalo,
MAX
Similar Threads
131 new feed links added to my website jasonpeoria911 Streaming / Broadcasting / Audio Recording 4 08-02-2008 09:53 AM
Another big update, 299 new feed links added to scannerfeeds.us jasonpeoria911 Streaming / Broadcasting / Audio Recording 5 06-27-2008 07:10 PM
Wake County Leverages New Licensed 4.9GHz Public Safety Band scan83g North Carolina Radio Discussion Forum 0 04-17-2006 04:04 PM
Peoria County looking at safety upgrade tweatherford Illinois Radio Discussion Forum 6 10-19-2005 09:09 PM
Franklin County public safety system upgrades wa8pyr Ohio Radio Discussion Forum 23 06-19-2005 09:54 PM
