Provoice using DSD
glock318
its not encrypted just ProVoice, I bought a P7100 and programmed it inverted on the control channels and can hear all traffic
Forts
Mentor
Ontario, Canada
Problem solved :)
Not sure what you mean by 'programmed them inverted on the control channel' though...
glock318
MA/com repeaters invert the digital voice when it passes through the repeater so basically it comes out "backwards" which is why the MA/Com Harris radios have an option in programming to RX "invert" so it can hear the transmission.
Forts
Mentor
Ontario, Canada
I've seen that option in the software... Just never had to use it with any of the systems I've programmed before.
kca6720
KCA6720
Yes, DSD for win works. I use a GRE PSR800 and I would say it tracks and decodes about 99% of the calls.
