Monitor MAUI radio traffic?
rwaymire
Sammamish, WA
Is anyone successfully monitoring radio traffic in MAUI? I've loaded in the LTR system, the "new" P25 system, and the UHF P25 Public safety channels into my WS1088 but not getting anything.
Sybex7254
Florida
New Maui system isn't LTR, it's P25 Phase II. They could be encrypted?? I'm off island so can't help much. Last I heard them was monitoring the LTR channels in conventional mode.
rwaymire
Sammamish, WA
Yes, I think I'm just learning P25. With just the control channels, nothing was coming through. Needed all the frequencies programmed. Also, had to add wildcard monitoring not just for talkgroups but for Radio IDs as well. Perhaps that's just Whistler specific....
Sybex7254
Florida
Sorry I'm all Uniden radios these days. I just have to update the DB in my scanner every so often and I'm set. In fact I'll have to bring my BCD436HP with me in April when I go back because my scanner there is only Phase 1.
Edit: There is a live audio stream up and running http://www.broadcastify.com/listen/ctid/546
Not Encrypted so you should be able to hear them. I was able to receive the old LTR channels very well from the Big Island with a back of set antenna so I would assume the same with the new TRS. I also used to get the as very strong signal on the control channel for the new TRS before they migrated to it.
scan18
Honoka'a, HI
I am able to pick up the East Maui and "Site-004" sites on my Pro-668 from the Hamakua area on the Big Island. The East Maui site comes in pretty strong, but not a ton of traffic. The "Site-004" site (not sure where that is located) comes in ok, but not great. I have the Pro-668 hooked up to a poor outdoor antenna currently which is fine for my local needs. I've been thinking of getting a better directional antenna and pointing it towards Maui.
Fireboat03
Pepsima1 Duplicate Account
Banned
I am able to pickup Maui P25 Phase II system from The Big Island of Hawaii tonight. From Waikoloa I can pickup two sites. Was able to pickup Waimea Site 17 and Maui site 14 this evening with no issues. Also, I am able to pickup the Lanai Site 12 too with semi good. Receive comes in nice and clear. I am receiving on the Uniden BCD996P2 with a radio shack 800mhz rubber duck antenna. These antenna's tend to pickup 700/800 mhz nice and sweet
I was able to monitor these talkgroups that I will submit to the DB. These are my findings so far with good accuracy
5500 - Maui Fire Dispatch Paging
5510 - Maui Fire Dispatch
5110 - Maui PD
5120 - Maui PD
5130 - Maui PD - Lahaina
5150 - Maui PD - Kihei
Some mobile radios are tranmitting in secure encrypted mode. Not all though. All Dispatch talkgroups are in the clear
shthomps808
Honolulu, HI
Does anyone have updated talkgroup and trunking info for Maui County P25 Phase II Public Safety Radio System? Updated talkgroup info here is incomplete as Maui PD has 6 districts with talkgroups assigned to each district, as well as Maui Fire, Maui Ocean Safety, and Medics. Thanks.
scan18
Honoka'a, HI
I think this is the best you'll get for now... Probably not a huge number of listeners.
If you have any updated info on the talkgroups, feel free to submit them to the database.
MtnBiker2005
San Diego County, California
System 5F7 Pro96com Reports - Maui County Regional Interoperable P25 Public Safety
Updated Info for this system. :D
System 5F7 Pro96com Reports - Maui County Regional Interoperable P25 Public Safety Radio System
http://www.radioreference.com/apps/db/?sid=5976
__________________________________________________________________________________
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) : WQSS359 - http://www.radioreference.com/apps/db/?fccCallsign=WQSS359
Timestamp : Tue Mar 21 20:21:59 2017
SITE NAC: 5F1
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,935.01250,0.01250,-39.00000,"Confirmed",0.01250,1
05,935.01250,0.01250,-39.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0015","i",851.10000,"00-0015",806.10000,0,1
"00-0095","d",851.60000,"00-0095",806.60000,1,0
"00-0175","d",852.10000,"00-0175",807.10000,1,0
"00-0335","a",853.10000,"00-0335",808.10000,0,0
"00-0367","a",853.30000,"00-0367",808.30000,1,0
"00-0415","c",853.60000,"00-0415",808.60000,1,0
"02-0094","v",851.60000/0,"02-0094",806.60000/0,1,10
"02-0095","v",851.60000/1,"02-0095",806.60000/1,0,11
"02-0174","v",852.10000/0,"02-0174",807.10000/0,1,7
"02-0175","v",852.10000/1,"02-0175",807.10000/1,1,8
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency
103,"T0103",5f7,"00-0441",853.76250
104,"T0104",5f7,"01-1850",773.56875
112,"T010C",5f7,"00-1001",857.26250
117,"T0111",5f7,"00-1037",857.48750
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-3
Tower Number (Hex) : T0103
Flavor : Phase 2
Timestamp : Wed Mar 22 02:48:29 2017
SITE NAC: 5F3
-Tables
-Frequencies
"00-0087","i",851.55000,"00-0087",806.55000,0,7
"00-0117","d",851.73750,"00-0117",806.73750,0,0
"00-0247","d",852.55000,"00-0247",807.55000,1,0
"00-0281","a",852.76250,"00-0281",807.76250,0,0
"00-0407","a",853.55000,"00-0407",808.55000,0,0
"00-0441","c",853.76250,"00-0441",808.76250,1,0
"02-0116","v",851.73750/0,"02-0116",806.73750/0,0,165
"02-0117","v",851.73750/1,"02-0117",806.73750/1,1,162
"02-0246","v",852.55000/0,"02-0246",807.55000/0,1,158
"02-0247","v",852.55000/1,"02-0247",807.55000/1,1,165
-Neighbors
101,"T0101",5f7,"00-0415",853.60000
105,"T0105",5f7,"00-0969",857.06250
106,"T0106",5f7,"00-0277",852.73750
107,"T0107",5f7,"00-1109",857.93750
110,"T010A",5f7,"00-1269",858.93750
111,"T010B",5f7,"00-0837",856.23750
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-4
Tower Number (Hex) : T0104
Flavor : Phase 2
Call Sign(s) : WPTZ784 - http://www.radioreference.com/apps/db/?fccCallsign=WPTZ784
Timestamp : Tue Mar 21 18:20:44 2017
SITE NAC: 5F4
-Tables
-Frequencies
"01-1350","i",770.44375,"01-1350",800.44375,0,1
"01-1390","d",770.69375,"01-1390",800.69375,0,0
"01-1430","d",770.94375,"01-1430",800.94375,1,0
"01-1770","a",773.06875,"01-1770",803.06875,0,0
"01-1810","a",773.31875,"01-1810",803.31875,0,0
"01-1850","c",773.56875,"01-1850",803.56875,1,0
"03-1390","v",770.69375/0,"03-1390",800.69375/0,1,12
"03-1391","v",770.69375/1,"03-1391",800.69375/1,1,14
"03-1430","v",770.94375/0,"03-1430",800.94375/0,0,12
"03-1431","v",770.94375/1,"03-1431",800.94375/1,1,11
-Neighbors
101,"T0101",5f7,"00-0335",853.10000
108,"T0108",5f7,"00-0433",853.71250
109,"T0109",5f7,"00-0375",853.35000
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-5
Tower Number (Hex) : T0105
Flavor : Phase 2
Call Sign(s) : WQSS939 - http://www.radioreference.com/apps/db/?fccCallsign=WQSS939
Timestamp : Tue Mar 21 22:21:13 2017
SITE NAC: 5F5
-Tables
-Frequencies
"00-0353","i",853.21250,"00-0353",808.21250,0,1
"00-0757","a",855.73750,"00-0757",810.73750,1,0
"00-0969","c",857.06250,"00-0969",812.06250,0,0
"02-0446","v",853.80000/0,"02-0446",808.80000/0,1,1
-Neighbors
116,"T0110",5f7,"00-0869",856.43750
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-6
Tower Number (Hex) : T0106
Flavor : Phase 2
Call Sign(s) :
Timestamp : Tue Mar 21 22:24:09 2017
SITE NAC: 5F6
-Tables
-Frequencies
"00-0233","a",852.46250,"00-0233",807.46250,0,0
"00-0277","c",852.73750,"00-0277",807.73750,1,0
-Neighbors
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-7
Tower Number (Hex) : T0107
Flavor : Phase 2
Call Sign(s) : WQSA728 - http://www.radioreference.com/apps/db/?fccCallsign=WQSA728
Timestamp : Tue Mar 21 22:51:05 2017
SITE NAC: 5F7
-Tables
-Frequencies
"00-0717","i",855.48750,"00-0717",810.48750,0,1
"00-0949","d",856.93750,"00-0949",811.93750,1,0
"00-1029","a",857.43750,"00-1029",812.43750,0,0
"00-1109","c",857.93750,"00-1109",812.93750,0,0
"02-0948","v",856.93750/0,"02-0948",811.93750/0,1,2
"02-0949","v",856.93750/1,"02-0949",811.93750/1,1,2
-Neighbors
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-8
Tower Number (Hex) : T0108
Flavor : Phase 2
Call Sign(s) : WQSL269 - http://www.radioreference.com/apps/db/?fccCallsign=WQSL269
Timestamp : Tue Mar 21 06:58:15 2017
SITE NAC: 5F8
-Tables
-Frequencies
"00-0073","di",851.46250,"00-0073",806.46250,0,1
"00-0233","d",852.46250,"00-0233",807.46250,1,0
"00-0277","a",852.73750,"00-0277",807.73750,0,0
"00-0433","c",853.71250,"00-0433",808.71250,0,0
"02-0072","v",851.46250/0,"02-0072",806.46250/0,1,2
"02-0073","v",851.46250/1,"02-0073",806.46250/1,0,3
"02-0232","v",852.46250/0,"02-0232",807.46250/0,1,6
"02-0233","v",852.46250/1,"02-0233",807.46250/1,1,7
-Neighbors
114,"T010E",5f7,"00-1077",857.73750
115,"T010F",5f7,"00-1109",857.93750
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-9
Tower Number (Hex) : T0109
Flavor : Phase 2
Timestamp : Tue Mar 21 16:57:12 2017
SITE NAC: 5F9
-Tables
-Frequencies
"00-0037","di",851.23750,"00-0037",806.23750,0,1
"00-0127","d",851.80000,"00-0127",806.80000,0,0
"00-0193","a",852.21250,"00-0193",807.21250,1,0
"00-0375","c",853.35000,"00-0375",808.35000,1,0
"02-0036","v",851.23750/0,"02-0036",806.23750/0,0,3
"02-0037","v",851.23750/1,"02-0037",806.23750/1,0,1
"02-0126","v",851.80000/0,"02-0126",0.00000/0,1,45
"02-0127","v",851.80000/1,"02-0127",0.00000/1,1,41
-Neighbors
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-10
Tower Number (Hex) : T010A
Flavor : Phase 2
Timestamp : Sun Mar 19 02:49:20 2017
SITE NAC: 5FA
-Tables
-Frequencies
"00-1189","a",858.43750,"00-1189",813.43750,0,0
"00-1269","c",858.93750,"00-1269",813.93750,1,0
-Neighbors
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-11
Tower Number (Hex) : T010B
Flavor : Phase 2
Timestamp : Tue Mar 21 07:51:29 2017
SITE NAC: 5FB
-Tables
-Frequencies
"00-0295","i",852.85000,"00-0295",807.85000,0,3
"00-0455","a",853.85000,"00-0455",808.85000,1,0
"00-0837","c",856.23750,"00-0837",811.23750,0,0
"02-0360","v",853.26250/0,"02-0360",808.26250/0,1,16
"02-0361","v",853.26250/1,"02-0361",808.26250/1,1,22
-Neighbors
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-12
Tower Number (Hex) : T010C
Flavor : Phase 2
Timestamp : Tue Mar 21 18:51:07 2017
SITE NAC: 5FC
-Tables
-Frequencies
"00-0055","i",851.35000,"00-0055",806.35000,0,1
"00-0255","d",852.60000,"00-0255",807.60000,0,0
"00-0793","a",855.96250,"00-0793",810.96250,1,0
"00-0841","a",856.26250,"00-0841",811.26250,0,0
"00-1001","c",857.26250,"00-1001",812.26250,0,0
"02-0196","v",852.23750/0,"02-0196",807.23750/0,1,1
"02-0197","v",852.23750/1,"02-0197",0.00000/1,1,1
"02-0255","v",852.60000/1,"02-0255",807.60000/1,1,1
-Neighbors
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-14
Tower Number (Hex) : T010E
Flavor : Phase 2
Call Sign(s) : WQSX939 {site sending wrong callsign}
Timestamp : Tue Mar 21 16:24:31 2017
SITE NAC: 5FE
-Tables
-Frequencies
"00-0215","i",852.35000,"00-0215",807.35000,0,1
"00-0797","d",855.98750,"00-0797",810.98750,1,0
"00-0913","d",856.71250,"00-0913",811.71250,0,0
"00-0997","a",857.23750,"00-0997",812.23750,0,0
"00-1077","c",857.73750,"00-1077",812.73750,1,0
"02-0796","v",855.98750/0,"02-0796",810.98750/0,1,8
"02-0797","v",855.98750/1,"02-0797",810.98750/1,1,5
"02-0912","v",856.71250/0,"02-0912",811.71250/0,1,7
"02-0913","v",856.71250/1,"02-0913",811.71250/1,1,6
-Neighbors
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-15
Tower Number (Hex) : T010F
Flavor : Phase 2
Call Sign(s) : WQST735 - http://www.radioreference.com/apps/db/?fccCallsign=WQST735
Timestamp : Tue Mar 21 15:23:56 2017
SITE NAC: 5FF
-Tables
-Frequencies
"00-0813","i",856.08750,"00-0813",811.08750,0,1
"00-1029","a",857.43750,"00-1029",812.43750,1,0
"02-0812","v",856.08750/0,"02-0812",811.08750/0,1,15
"02-0813","v",856.08750/1,"02-0813",811.08750/1,1,16
-Neighbors
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-16
Tower Number (Hex) : T0110
Flavor : Phase 2
Timestamp : Tue Mar 21 08:20:47 2017
SITE NAC: 5F6
-Tables
-Frequencies
"00-0327","i",853.05000,"00-0327",808.05000,0,2
"00-0357","d",853.23750,"00-0357",808.23750,1,0
"00-0401","d",853.51250,"00-0401",808.51250,1,0
"00-0437","a",853.73750,"00-0437",808.73750,1,0
"00-0869","c",856.43750,"00-0869",811.43750,0,0
"02-0356","v",853.23750/0,"02-0356",808.23750/0,1,18
"02-0357","v",853.23750/1,"02-0357",808.23750/1,0,20
"02-0400","v",853.51250/0,"02-0400",808.51250/0,1,19
"02-0401","v",853.51250/1,"02-0401",808.51250/1,1,15
-Neighbors
Frequencies Usage Codes:
a - Alternate Control Channel
C - Control Channel
d - Data
i - System site FCC ID information
v - Voice
MtnBiker2005
*continue of the above post*
-TowerInfo
System ID : 5F7
WACN : BEE00
Tower Number (Decimal): 1-17
Tower Number (Hex) : T0111
Flavor : Phase 2
Timestamp : Tue Mar 21 21:53:12 2017
SITE NAC: 5F7
-Tables
-Frequencies
"00-0135","i",851.85000,"00-0135",806.85000,0,1
"00-0273","a",852.71250,"00-0273",807.71250,1,0
"00-1037","c",857.48750,"00-1037",812.48750,0,0
"02-1240","v",858.76250/0,"02-1240",813.76250/0,0,1
"02-1241","v",858.76250/1,"02-1241",813.76250/1,1,1
-Neighbors
Talkgroups Logged:
5110
5120
5130
5140
5150
5160
5220
5500
5510
5550
5580
5700
5720
5750
5790
5820
5910
RadioIDs Logged:
12,13,19,22,24,54,56,57,62,63,73,75,77,84,85,91,93,96,
101,105,115,118,122,134,136,144,152,160,167,169,171,176,184,188,191,
209,210,214,217,227,228,229,238,252,257,261,268,272,276,277,280,284,286,291,
302,308,309,310,313,316,320,321,327,336,338,340,347,348,
356,360,365,369,370,371,375,378,380,382,389,393,397,
1042,1043,1044,1049,1101,1105,1299,1319,1353,1370,1410,1414,1563,1566,1645,1666,
2022,2024,2027,2029,2030,2031,2032,2037,2039,2068,2070,2072,2073,2075,2079,
2082,2085,2086,2089,2091,2092,2093,2094,2095,2097,2098,2099,
2102
2220,2226,2229
2321,2324,2325
2422,2423,2424,2428,2429,2432,2435,2443,2446,2447,2448,2449,2451,
2517,2518,2530,2532,2540,2543,2544,
2628,2635,2638,2639,2642,2643,2644,2645,2646,2647,2648,
2960
3000,3005,3006,3008,3010,3035,3042,3080,3085,3086
3100,3112,3141,3190,3191
3415,3447,3455
3510,3521,3545,3555,3556,
3632
3790
3845,3850,3851,3852,
3922,3925,3980,
4021,4022,4030,4095,
4100,4102,4103,4105,4120,4130,4135,
5003,5062,5079,5096,5098,
5140,5159,5171,5172,5173,
5215,5216,5217,
5436,5438
5582,5584,5597,5598,
5612
5912
6315,6506,6509,6725,6952,6990,6992,6996,
7865
8283
10036
15006,15225,15226,15227,
16000,16001,16002,16003,16004,16017,16018,
