Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW Equipment
HF/MW/LW Equipment - For general and technical discussion of all receivers which cover the HF bands. For HF tranceiver discussion please use the Amateur Radio Equipment forum above.
  #41 (permalink)
Old 10-11-2017, 1:19 PM
Join the RF-2200 Yahoo users group, they may have some leads. There is a service manual and if you have the proper test equipment you can do it yourself. I aligned my Panasonic DR-22 (the RF2200's European cousin) but I am not in the business.
I think there is a fellow who aligns them, that would be found on the RF-2200 site.
Is the radio not working properly?
  #42 (permalink)
Old 10-13-2017, 8:12 PM
Originally Posted by chgenoe2 View Post
I found an RF 2200 today at a local flea market for $15. I'm very new at this and I wanted to see if I could find a cheap used alternative before buying anything new, and I figured even if it didn't work for fifteen dollars it was worth a look. When I put batteries in it powered up. It does very well with FM, but AM and sw not so much. This afternoon with it indoors I get only static and whistling on AM and sw. Outside I got a few AM stations, or what sounded like the same two stations on different frequencies, and still nothing on sw. Tonight I did get some faint stations on sw, but only on sw1 and sw2, and no AM at all. So, is there anything I can do to improve reception? I'm not sure if I'm capable of cleaning the inside as I've read some have done. Any suggestions?
The problems you experienced with your RF-2200 are exactly the same problems I had with the RF-2200 I bought on eBay earlier this year. When I first put batteries in the radio, all the dial lights lit up but there was no sound on any of the bands other than static and whistling. I had to clean all the radio's pots and switches TWICE with De-Oxit and let the radio sit overnight before my RF-2200 finally sprang to life. I now use it as one of my primary AM DX radios, and everything that's been said about the MW performance of the RF-2200 is true. I'm glad I took the time to thoroughly clean all the pots and switches before assuming that the radio was DOA. Electronics from the 1970's and early 1980's don't get better with age, so it's always a good idea to give these radios a through cleaning and deoxidizing before use.
  #43 (permalink)
Old 10-14-2017, 1:42 AM
The particular problem with the Panasonics and Sonys of that era was the extensive use of slide switches, which were highly prone to oxidation over time, and (at least in the case of the Sony I have that refuses to operate on SW) difficult to reach with a nozzle -- on top of that, the way the switches were linked to the actual button on the front of the radio sometimes made for questionable contact, which doesn't help much.
Glad to hear you were able to get your 2200 to work. My 5900W still is only partially working. Not one of Sony's best efforts. :-(
