Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW Equipment
HF/MW/LW Equipment - For general and technical discussion of all receivers which cover the HF bands. For HF tranceiver discussion please use the Amateur Radio Equipment forum above.
  #21 (permalink)
Old 08-15-2017, 6:49 AM
My guess is that the power supply, "charger", adapter, wall-wart, whatever you want to call it is nothing more than a 6 volt power supply and the actual charging smarts are probably in the radio itself. Therefore, most any adequately rated 6 volt supply should do the job. However, have been unable to find a schematic for the PL-600 so this is speculation on my part. Hence, my suggestion to check with the vendor.
Anyway, if another 6 volt power adapter is acceptable, don't worry too much about the plug as it can be obtained separately if necessary. Just make sure you observe polarity... center pin negative.
  #22 (permalink)
Old Yesterday, 7:05 PM
Any update on this? What have you been able to find out or come up with?
