Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW Equipment
HF/MW/LW Equipment - For general and technical discussion of all receivers which cover the HF bands. For HF tranceiver discussion please use the Amateur Radio Equipment forum above.
Old 08-22-2018, 9:36 PM
Default Need a New SW Radio... Ideas?
I really want a reciever with a huge frequency span, small enough to take camping and to a hotel, but powerful.
I would like it to be both AC and DC. And I want the ability to fine tune in the frequency. All modes and many filter options.
I am willing to spend up to $1,000.
Any good ideas?
Old 08-22-2018, 9:50 PM
I would consider the Grundig S-750 for a receive only rig or
the Yaesu FT-817ND which is an all mode 5 watt rig.
Best of luck.
Frenchie, N3UFJ
Old 08-22-2018, 11:02 PM
majoco's Avatar
You probably don't mean powerful, you mean 'sensitive'. The Grundig Satellit 750 has been discontinued, but I guess the Tecsun S2000 is still available - way below your price top line and they don't have continuous coverage to 1000MHz! AC and batteries is no problem, any battery radio worth its salt these days comes with rechargeables. For a "DC to daylight" receiver you'd be looking at silly money for a big Icom receiver and they won't run on batteries or be portable. You might try the new Icom R30...
https://www.icom.co.jp/world/product...ndheld/ic-r30/
...and it's only US$600 from Universal Radio - seems to meet all your requirements including SSB and all the digital formats.
https://swling.com/blog/2018/08/dave...band-receiver/
Old 08-22-2018, 11:16 PM
safetypro79's Avatar
Arrow Best options
CommRadio CR1a, when you can find one. **My first choice
Palstar R-30A,
Both require an external antenna, I.e. reel wire type (best option)
Old 08-22-2018, 11:32 PM
gonefishn1's Avatar
ICOM R-30 might work for ya.
Uniden BCD436HP, BCD536HP
Old 08-23-2018, 12:32 AM
Looks like the Comm-Radio CTX-10 transceiver is only $1 under your budget, and is finally released - at least at Universal.
That might do the trick for your broad needs.
Old 08-23-2018, 1:13 AM
majoco's Avatar
He did say 'receiver'.
Old 08-23-2018, 7:13 AM
krokus's Avatar
If you are taking a computer with you, check out SDRs.
Sent using Tapatalk
Old 08-23-2018, 7:43 AM
Wiki Admin Emeritus
Sent using Tapatalk
And you can research this topic using our wiki which has an extensive listing of SDRs here...
Software Defined Radios - The RadioReference Wiki
co-author, HF Digital Decoding
bgav's Avatar
OP: Clarification of receiver vs transceiver would be helpful.
HP-2 | BCD436HP | PSR-800 Whistler Upgraded | IC-R30 | Yaesu VX-6R
Old 08-23-2018, 9:53 AM
The "many filter options" thing sorta eliminates everything except a wideband ("huge frequency span") communications style receiver... not very portable and beyond your budget. Unless... you go SDR, but then you have to lug around a computer.
Old 08-24-2018, 3:32 AM
You don't say enough about what you want. You mention camping, and mention listening in a hotel.
I doubt an SDR will be easy to use camping, for example.
You may want to look into a Tecsun PL880 (several filters, SSB, works well off internal & whip antenna, has external antenna jack) or a Sangean 909X (high quality for a portable, can work off an external antenna).
In a hotel you'll be dealing with RFI galore if you plan to listen to SW or HF.
