Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW Equipment
HF/MW/LW Equipment - For general and technical discussion of all receivers which cover the HF bands. For HF tranceiver discussion please use the Amateur Radio Equipment forum above.
Old 12-05-2018, 8:14 PM
Default Panasonic rf-b65d
Panasonic RF-B65D
If any one have this radio tell me how many hours the battery stay in it ? (The radio battery not clock and backup battery).
I want to know if the battery drain in my radio.
Thank you.
Old 12-06-2018, 4:04 PM
I have an RF-B45, the B65's later cousin, and my RF-B45 is not terrific on batteries. Slightly different circuits from the RF-B65, though....
I have never measured the hours the batteries last on my RF-B45, but I have other, similar radios (Sangean brand SW radios) that have longer battery life (the Sangean 800A is an example).
I found a review of the RF-B65, and in a comment below the article a guy says that his RF-B65 "really went through batteries fast".
So maybe your radio is OK. It just uses batteries more than other radios do.
Here is the review. The comment I mention is at the bottom of the review:
https://swling.com/blog/2017/04/the-...amongst-dxers/
Old 12-07-2018, 9:52 PM
I'm using eneloop 2100 mah rechargable battery which power radio for about 18 hours
Old 12-08-2018, 9:48 AM
I probably get 20 or so hours off of my RF-B45.
I have never measured it -- this is just a guess.
But I only use headphones.
If you use headphones only, you will get a lot more battery time from your radio.
Old 12-08-2018, 6:01 PM
The problem is in the radio it is draining battery because when power is off it draining battery and 6v dc in not working perhaps it has short that made battery draining.
Any one had solution for this problem.
And thank you in advance.
Old 12-09-2018, 10:13 PM
No one has solution
Old 12-10-2018, 10:43 PM
Any SW radio with a microprocessor and a clock is going to drain the battery a little even when the radio is off. The microprocessor and clock need power to work.
If your radio's batteries only last 18 hours if the radio is just sitting; yeah, there might be a problem with the radio.
RE: Rechargeable batteries: some do not put out the same amount of juice as standard batteries do.
It is possible your 6V adapter itself does not work. Have you tested it for voltage output?
Old Yesterday, 7:50 AM
I found the problem , the problem is cleaning well the battery terminals and contact directly to the board.
after that the battery work for 32 hours continues.
Thank you
Old Yesterday, 11:02 PM
I am glad to hear you got your RF-B65 working well.
I have read that it is an excellent radio.
If it is like my RF-B45, it probably is.
73 and good DX.
