Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW General Discussion
HF/MW/LW General Discussion General discussion on monitoring the HF (High Frequency), MW (Medium Wave), and LW (Long Wave) spectrum (0.5 - 30 MHz)
Old 01-13-2009, 04:58 PM
Default Neibor CB bleeds through our speakers in our house
IF this dont belong here then move it...
However In my house a neighbor using thier CB often bleeds through on various speakers
in our house.
It happened on my LAptop my television AND my living room's desktop speakers.
Im thinking about writting the FCC.
But what evidence would I present to them?
Thanks In Advance
Crista
PS I reside in Decatur,Illinois
so this can go in the Illinois forum as well
And I mispelled LOL its ok not the end of the worlds LOL
Old 01-13-2009, 05:05 PM
Rekd's Avatar
Have you talked to him/her about the problem?
What's in your sippy cup?
___ □ □_
[l_,[____],
l---L - OlllllllO-
( )_) ( )_)--)_)
San Diego
Kids that Hunt, Trap and go Fishing, don't mug little old Ladies.
Old 01-13-2009, 05:27 PM
in our house.
Thanks In Advance
Crista
The vast majority of interference complaints the FCC gets are not the fault of the transmitter.
The TV _might_ be his fault. I doubt the laptop is.
I second the idea of talking to him first.
Some posts can be interpreted in various ways.
Mine generally mean exactly what they say.
Old 01-13-2009, 07:40 PM
Question
First read the manual for your TV,Laptop ,Scanner.The attaiude of the FCC in interferance is TS.
2nd your speaker wire is acting like an antenna (you need a rf choke on the speaker leads)
3rd is your TV connected to cable / outside antenna ?(you need a lo-pass filter-usually free if you write the
manufactor of your TV.
4th write the laptop manufactor for help ?
Hope this helps,but do work with the CB'er ,that is what the FCC will ask you first.
Ray
Old 01-13-2009, 09:09 PM
A stock CB is very unlikely to cause the problem as described and if the neighbor is running a CB with an amplifier that's a legal problem for them. Are you sure its CB or could it be the higher power amateur radio service?
If you have any friends with a CB in their car have them park close to your house and see if that interferes. If so the problem is now yours but if not and the neighbor is actually using a CB then this would be good info to make a case with the FCC.
prcguy
Old 01-13-2009, 09:14 PM
If a CB'er is getting into all that, it begs the question... How much power is he running? A legal 4 watts is highly unlikely to cause that much stray rf pickup. Are you sure it's a cb'er, and not an amateur? Talk to him and find out. Let him know what's going on.
The FCC has lot's of nifty information about interference and what to do about it:
http://www.fcc.gov/cgb/consumerfacts/interference.pdf
12 volt radios are for wimps. Real radios can kill you.
Old 01-14-2009, 12:02 AM
mikeATtleccdotnet's Avatar
Your all missing the point, he has approximately 8 foot speaker leads, or an odd multiple in length. Chances are, he(CBer) is legal, but just coupling to the leads. Put a choke with a few turns on each end of the speaker leads and it will correct this issue.
Does the sound, sound like a WaWa or can you actually make out what he is saying? If it's the WaWa type of sound then it's SSB, if not, it will be AM. FM does not modulate speakers. Most likely, if you tune your TV, off air, on to channel 5, you will also have this interference if it's high power. otherwise, it's just coupling to the leads of your speakers.
Does any one remember what 96" is equal to? Shorten or lengthen your speaker leads, see what happens…
-Mike
Old 01-14-2009, 01:24 AM
Thanks all for your help
Im not sure exactly what neighbor it is.
Even If I did I'm a gal so the fear of assault deters me.
That having been said it only happens when the TV or computer is off.
These are standard cheap plug and play speakers.
And Ive turned on my scanner to confirm that its CB AM
No SSB or anything like that.
Were moving pretty soon to a nicer house so Ill probaly just let it go.
I have to admit though it scared the heck out of me the first couple of times it happened.LOL
I lived ALL through the US of A LOL
and this is THE first time Ive encountered such a problem.
So now at least I have something to tell my kids about lol
Old 01-14-2009, 01:44 AM
k9rzz's Avatar
Here's a novel approach ... go buy your own CB for $40 and holler at him for messing up your stereo! Then you wouldn't have to knock on his door.
Old 01-14-2009, 02:34 AM
bballjh's Avatar
Send a message via AIM to bballjh Send a message via Yahoo to bballjh
HA! Good point. Or just get a radio and pump massive amounts of power through it and give him a dose of his own medicine
@Juss10 (Follow Me)
@OlyScanner (Live scanner updates blog)
Pro-97
Thurston County, Wa
Old 01-14-2009, 02:59 AM
Shortwavewave's Avatar
Send a message via Yahoo to Shortwavewave
Or you could fill your house, porch, and garadge with CFL(swrillys) lights.
And buy 20 Neon Lamps so he couldnt hear a cb radio right next to his.
Ernie
Banshee Soundcard VLF Reciver 0-22kz
http://radiowavelistener.blogspot.com/
Old 01-14-2009, 05:24 AM
LOL
I know huh LOL
Old 01-14-2009, 06:24 AM
LOL that will show him
[Pro-83] [Bearcat 210XL] [BCT-7]
Old 01-14-2009, 06:40 AM
In that case, I doubt it is the fault of the transmitter.
Ferrite and capacitors would be my first try.
Old 01-14-2009, 08:50 AM
hoser147's Avatar
Thats funny my daughter and her neighbors have the same issue with a guy in her bloclk, I told her next time she see's him outside to say something to him. One neighbor already went door to door to see if it was just his house and wanted to report it. But they are all just waiting to see whats going on. Kind of the same deal the TV speakers, stereo speakers and even the alarm clock speakers. From the outside the guy has a very nice setup.
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 01-14-2009, 09:54 AM
I have several amplified computer speakers and approximately 8ft speaker leads on my stereo and I can run 1200w on 10m or any other amateur band without a peep from my speakers or my neighbors. I don't really care if someone runs a million watts on CB as long as they don't cause interference to other services. If someone is running an amplifier on CB and causing another person harm then it should be killed or fined.
prcguy
-Mike
Old 01-14-2009, 10:27 AM
rfradioconsult's Avatar
Here is a link regarding legislation enacted in 2000 regarding enabling state and local authorities to enact and enforce CB interference on a local level.
http://levin.senate.gov/newsroom/release.cfm?id=210612
Old 01-14-2009, 11:55 AM
dave3825's Avatar
Drive around your neighborhood and look for any antennas other than TV antennas on the roofs. That should narrow it down unless the guy is using a mobile antenna..
«::D::» «::A::» «::V::» «::E::» «::3::» «::8::» «::2::» «::5::»
Br330T
Pro 93 tapped
Pro 95 tapped
Arc330Pro
BcTool
Old 01-14-2009, 02:25 PM
kb2vxa's Avatar
HEY CHRIS, WHERE YA BEEN YA OL' BAG O' SNAKES?!?!?!
It's good to see you back again but hey, since you're moving the point becomes rather moot. I see no point in aggravating yourself or going through all the changes, just hang in there and when the time comes kiss the baby goodbye.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 01-14-2009, 03:04 PM
Send a message via AIM to brey1234
Unhappy my experience
I had a neighbor who had an old TV and was complaing that I was coming through his TV when the Tv was OFF!
Obviously there was some coupleing going on and it was NOT my fault. But nothing I said would convince him of that.
But I then found out this neighbor had a terminal illness. I went off the air for a few months until he died. I had the "right" to go on with my hobby but did not want to stress out a guy who was dying.
Bob Reynolds-WB3DYE
Similar Threads
LoJack leads police to wrong house ki7be Nevada Radio Discussion Forum 14 Today 12:52 AM
need help with new installation at old house blueangel-eric Antennas and Coax Forum 3 08-22-2008 08:50 PM
Open House Montgomery County & DC ScanManQSL Maryland Radio Discussion Forum 0 10-14-2007 11:28 PM
Fatal house fire, as paged last night jimmnn Colorado Incidents and Breaking News 0 04-07-2007 05:27 PM
External speakers? JWhipple General Scanning Forum 15 07-13-2005 10:55 PM
