Originally Posted by nickcarr
I went to their web site and had a look at the product. I didn't realize it was using a speaker/mic to pick up its signal.
A couple of pointers:
1. Make sure your in LSB mode on your NRD-545
2. Lock on to a strong CW signal
3. Switch to CW mode when you have a strong signal. Then isolate it's center frequency. Usually it's a common offset such as 14.010.25 or 14.010.75
4. The pitch of the sound should be low. (Think of someone whistling - it'll be lower than that.)
5. Put your RF gain and PLL dials in the middle position to start.
6. Do NOT use any noise reduction settings (this will likely mask the true CW pitch.)
EDIT: If the WPM meter says it's > 50 then try cranking the RF gain down a quarter of turn.
Good suggestions, Nick. I found that the microphone is useless, so I start by tuning into a strong signal and then plugging directly into the unit's line in through the headphone jack.
Why should I be in LSB? I tried both USB and LSB, and found that nearly all of the readable signals were in USB. There weren't that many in LSB at all. Also, I found that the CW mode actually caused more problems than leaving it in wide or narrow band.
As far as the "controls" go, I'm not sure, but I'm not sure whether this unit was originally supposed to come with 'knobs' or not. There are 'holes' where I would think knobs would be, but at the bottom there are two controls that can tweaked with tiny screwdrivers, which is what I am using. There are no markers that I can see that indicate high or low for these.
Can you also explain me the PLL thing, and how I align the unit's PLL setting and whatever frequency I'm using on the JRC? Don't quite get this part.
Last night I did have a little more luck--got two coherent readots. Of course, one of the problems with CW is that the transmissions only seem to last for 20 seconds or so (or I can only receive them for this amount of time), and then disappear entirely--i.e.,the transmitter doesn't seem to "come back" to that frequency again. Oh well.
Suzie
