Originally Posted by tonyclark
a metal rod that will fit the hole super glue on the end. might hold enough to pull out, or epoxy putty.
This is probably your best bet, but you'd have to *very* careful -- too much glue on the end can ruin the jack. Don't try this unless you have steady hands.
I think the best tool would be a dental pick. There's a pick that has a small hook on the end - this would probably do the job. You might be able to find it in a well-stocked drug store.
If you just don't feel comfortable then try to find an electronics repair shop (TV, etc.)
You probably have a HRO store (
HRO Ham Radio Outlet Worldwide Supplier of Amateur Radio Electronics Equipment) nearby - they would likely know of a good repair place.
