AM Radio IBOC - HD (Digital Radio on AM - (Bad!) -
Causing Digital Interference and Raised Noise Floor in many parts of the AM Band ...
This blocks / disables / degrades AM-DX and reception of weaker stations ...
Also causes reduced Signal-to-Noise-Ratio (SNR) of (even strong) signals ...
Here is a reprint of a recent letter I've written to iBiquity and FCC:
What has really happened is that a (Bad !) trade was made which
has degraded the overall performance of Analog AM Broadcasting
in order to squeeze in HD (Digital) Radio on AM ... IBOC (In-Band On-Channel) ... (Bad !)
It's also on FM but it's not as bad since FM signals are wider band / wider separated ...
Note that the degradation is two fold:
1) spectral pollution and raised noise floor of
neighboring frequency space ...
2) Self (own station) Digital and Analog mixing (in the receiver side)
creating an accompanying 'hiss' which further limits the achievable SNR of received AM stations ...
There is a file called IBOC_Observations.mp3 that has audio clip samples of the resulting IBOC
interference ... It sounds like an additive "hiss" on the signal ...
So in a way it's like a self-fullfilling prophecy ... first, HD (Digital) radio degrades the Analog AM
performance (with its bad effects which limits detection range and achievable SNR), and then says
"I have a fix for you - it's digital radio " ... outrageous ...
HD Radio itself is causing AM band problems ...
The decision to allow HD (Digital) IBOC radio on AM effectively
forsakes / denies / ignores the great tradition, legacy, and real capability of
long distance radio transmission (can be over 1000 miles) of
clear strong AM broadcasting (AM-DX / BCB-DX).
Basically, the philosophy tries to turn the AM band into
another localized short distance "FM" band ... This is because even though the analog signal
is still strong to even 50 KW transmit,
But on the receive side, which would be / can be working deep
into the noise and can still work with only a modest 6 dB SNR on the receive side ...
But now with adjacent channel (Digital) interference from
(Digital) sidebands the noise floor is artifically raised and thereby denying the weak stations to
make it through and be heard ... So HD (Digital) signal components have crapped up
the AM band / raised the noise floor with its digital interference ...
Taking away the use / reception of the lower amplitude portion of the dynamic range of received signals ...
I also question the competency and impartiality of the IBOC decision ... It's almost as if this was quietly slipped in on the American public ... and furthermore, I don't like it ... I wonder if any FCC officials / decision makers on this IBOC issue had any vested interests / monetary interests in HD Radio on AM / IBOC ... and what influences iBiquity had in the decision making process ... Sounds like a "collaboration" based on monetary gain for special interests without including the American public ...
(The largest broadcasters and equipment manufacturers - both transmit and receivers) ... It also pushes out smaller stations and operators ...
Sombody should review the whole process for conflicts of interest and impartiality ...
There are many websites on this ... The FCC approval (the FCC Did Not do their homework and
Did Not Do Their Job ! ) ... Some of those FCC officials looked at it more as generating sales of new radios rather than any technical considerations at all ! (like Bad Interference on the bandwidth tight AM Band !) ...
FCC IBOC HD Radio decision (documentation) in the Year 2002) …
DIYmedia.net - FCC Commissioners Adopt IBOC-DAB
Something stinks here ... Oh Yeah ... It's IBOC - HD Radio on AM
Victor L. Miller - Electrical Engineer / Radio Engineer
E-Mail:
vicmiller1@aol.com
