Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW General Discussion
HF/MW/LW General Discussion General discussion on monitoring the HF (High Frequency), MW (Medium Wave), and LW (Long Wave) spectrum (0.5 - 30 MHz)
Old 03-06-2013, 10:50 AM
Default Vatican Antenna Question
During the TV coverage of the Pope leaving the Vadican, a fly-over view showed a impressive antenna and tower. The antenna wa obviously two log-periodic type antennas, but their points merged into what may be described at a V shape on its side. Anyone know the brand of this antenna? Thanks.
Jerry AB5R
Old 03-06-2013, 12:33 PM
A similar antenna is located on the Vatican Embassy on Military Road in NW Washington DC. There was another of the same LPV type mounted for years on a tall office building (now condo apartments) in Silver Spring, Maryland, at 13th Street & Georgia Avenue. The story was that this one was owned by NOAA and was used for monitoring electronic weather buoys in the Atlantic Ocean.
Old 03-06-2013, 12:47 PM
Hmmmm? Thanks. Still would like to know Brand etc. Thanks again.
Old 03-06-2013, 1:53 PM
Wiki Admin Emeritus
Possibly you are seeing the MW tower of Vatican radio? If so, here's a page on the tower, along with what looks like a manufacturer's website
Vatican Radio Medium-wave Transmitter - Tower 1, Rome - SkyscraperPage.com
Old 03-06-2013, 5:02 PM
Yes, Mike, it could be, but I am interested in learning about that dual log-periodic V-shaped antenna.
Old 03-06-2013, 7:24 PM
Received another message from KD5RKO describing the antennas seen:
"That's a stacked array...the reason the arrays aren't parallel is so that the relative spacing is optimum over the entire frequency range of array. At HIPAS, we had a PYRIMID array of 4 wire log periodics for our ionosonde."
Thanks to ALL & 73. Jerry
