MWARA Frequencies
hi I wnted to know where new York radio goes after 7 am. Because I start listen to them in the evening around 7pm and listen all night. 3485 comes in after the sun comes up but I cant fine the airplane or controller calling. I tried 13354 and some other ones like 8891 ect but cant fine them. This also go far gander and the other one in the uk . last night 5616khz came in loud and clear airplane and controller. any help please. I use a par long wire antenna and satille 750 radio.
Go To:
HTTP://www.hfunderground.com/wiki/MWARA
Note that there are several maps dividing the world into various MWARA (Major World Aeronautical Route Areas)
On each individual map you will see little boxes with lists of frequencies in them.
Each little group of frequencies in a little box is a set used to maintain comms in a certain MWARA area.
The frequencies in the little boxes are changed at different times of the day according to changes in HF propagation.
The North Atlantic MWARA (of which New York Radio is just one part) is so busy compared compared to other MWARA that heavily used tracks (NAT-A, NAT-B, CAR-A) are almost exclusively assigned a certain set of frequencies.
NY Radio fades out because changes in the ionosphere do not support HF propagation on certain frequencies.
A very rough rule of thumb is during the day use frequencies over 10 mHz, at night use frequencies below 10 mHz.
Remember that this rule applies to the entire signal path. 7 AM is in NY is 12 noon in London, which means that the HF signal path for planes working NYRadio is almost entirely in daylight.
