Josh380
Didn't know where to post this..figured this was the closest fit.
As the title suggests, I'm losing audio from cable tv. It's weird. I turn on the tv (nothing fancy, just a crt tv, wega style), I get audio from all of the channels no problem for a good 15-20 minutes, then it fades out. If I shut it off for the same amount of time and turn it back on, the audio is back. If I switch to video 1 or any other input, I have audio all the time..no problems at all. My picture can get a little fuzzy on some of the channels, and if I mess with the cable at the tv end, it gets a little clearer, but for the most part I've come to terms with that as the occasional fuzzy channel doesn't bother me. What good is being able to see tv if I can't hear it? I could turn on subtitles, but c'mon, I can hear.
When I installed the cable in my room, I used standard RG-6 coax with those twist-on connectors. Everything tight, outdoor feed lines and T's are covered from weather. Could the twist on connectors be the root of the problem? Cable tv works fine in the rest of the house.
