Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Forum
ICOM Forum Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios and IDAS technology.
Old 06-18-2008, 10:44 AM
Default Icom F70T and F1821 MDC 1200 Feature Programming
I have a F70T Portable and F1821 Mobile. In the programming software I see nothing having to do with the MDC 1200 features. I am running CS-70/1700 software version 2.0. Any ideas?
--Scott
Old 06-18-2008, 12:15 PM
scancapecod's Avatar
ScanNewEngland Webmaster
Send a message via Yahoo to scancapecod
I have an 1821D and software version 2.2. I show an entire section in the software dedicated to MDC. I have not programmed any MDC features into the radio as of yet and I'm a relatively new owner, but it appears here that I could easily do it if need be.
Scott - Scan New England Webmaster
Old 06-18-2008, 12:48 PM
fireandems13669's Avatar
Send a message via AIM to fireandems13669 Send a message via MSN to fireandems13669 Send a message via Yahoo to fireandems13669
You should see A side menu that says MDC then click it to drop it down.If it is not showing up you may need to go the top and select the model.....
KC2VHB
Old 06-18-2008, 01:33 PM
That's probably it. If the radio is set as Portable BIIS PMR or Mobile BIIS PMR the MDC menu will not appear. All other possible radio settings offer MDC as a menu item.
Old 06-18-2008, 02:48 PM
It's gotta be my software version then. I'm not showing any MDC settings no matter what model I select.
--Scott
Old 06-19-2008, 12:24 AM
Are you sure you have the correct software even the1.1 has mdc all F70s are mdc1200
KC2VHB
Old 06-19-2008, 04:04 PM
I had the 2.1 software and all three of my radios (1821, F70 and F2821) didn't show the MDC options. I had someone read them with the 2.2 software and the MDC functions show on the 2821 and F70. However my 1821 is not showing the MDC options. Do I need to upgrade the firmware?
I have a question on the firmware also. Is it 1 Firmware file the will upgrade this entire series of radios? I'll probably start a new thread on the firmware thing.
Old 07-16-2008, 12:12 AM
Smile Ic 1721/f70 Mdc
First I did discover that there were two versions of programing software. 1 with MDC, 1 without.
We have aprox 100 F1721's all MDC enabled. But ran into an issue. Radios that were delivered later work fine with MDC PTTDown. First set of radio would not transmit with PTTDown set. But work fine with PTTUp. I believe it would be an FIRMWARE issue. Spoke to Icom Support. Read off versions to them they state should not be the issue that radio needs to be returned. We are talking 45+ units in active Fire and EMS units. Can't afford to take units out of service.
Can a current/newer firmware be found.
Thanks,
PS wish ICOM had more function buttons so that more of the MDC functions along with Normal daily could be used.
Old 07-16-2008, 04:33 AM
N2DLX's Avatar
Send a message via AIM to N2DLX
The latest firmware for analog radios is v2.6. Latest firmware for digital radios is v2.5. One firmware file can update both the portables and mobiles, it just depends if you're using digital or not.
To check your firmware version, turn off the radio. Then hold down P0 and P3 while turning the radio on, and it will display the radio's firmware, and the firmware of the P25 unit (if installed).
Old 03-16-2009, 09:43 AM
Larryfire26's Avatar
Send a message via AIM to Larryfire26 Send a message via Yahoo to Larryfire26
Default UPdated Firmware/software
Ok here is a good question:
You call Icom they say contact a dealer, ok you contact a dealer and they have no idea what you are talking about! So with that said where does one get the latest firmware /software for an f80dt with P25
I also have a 3061 any way that can have MDC on it or do I need to upgrade the radio
Larry W2LGB
Old 03-16-2009, 09:59 AM
RADIOGUY2002's Avatar
Send a message via AIM to RADIOGUY2002
Arrow 3061
3061 are not capable, only the 3161's are. The next version up, and yes their are dealers that have the right firmware. Just ask around and maybe you come into luck. Don't give up on just that one guy or dealer. The other issue is you may need to go back to the dealer that sold you your erquipment as some may not be so fourth coming in sharing.
As far as the ptt id down or up prolbems, ask Icom the give you loaners until the prolbem is reslove. Tell them you like their product and being in public saftey you need a turn key system. And if that does not work seek out management and advise of the sceranio. Somehow I think they'll make an effort to fix your equipment at that point, their tring to get in the business of public saftey. Not lose public saftey, you case story assuming everything is acurate (why it shouldn't be) already leaves bad tastes in people mouth of they were about to choose Icom. Their fore that alone should help make them step up to the plate, however not that I'm siding with Icom or you as I do not know all the details.
PS wish ICOM had more function buttons so that more of the MDC functions along with Normal daily could be used. I think we all wish for more function buttons for the more advanced users, but realistically how many of us are their that understand these concepts. You have to rember what the product is being marketed for. Not that I disagree with you by no means, more buttons is always a good thing, but how many buttons are too many? Take a look at the new p25 radios and see how many buttons are on those. Gradually change comes with the ability to peer review right, as long as people listen.
Thanks, Ryan. Seller of Icom & Kenwood Radios
GMRS=WQHR752
Icom and Vertex Equipment=F5061/F6061-5, F43/33-4, F3161/4161T-2, FR3000-1, VXR-7000(U)
Uniden=BC-396T & 996T
Old 04-05-2009, 01:27 PM
MaxTracker's Avatar
Send a message via ICQ to MaxTracker Send a message via Yahoo to MaxTracker
Larry W2LGB
You're contacting the wrong dealer. you might try contacting the Icom pro's: Two-Way Radios and Other Wireless Products and Solutions from BearCom
KF5CXT/WQIW237
Trenton, Texas USA
V-8000 - FT2800M - PSR600 - PRO106 - PRO160 - BC898T - IC-F221 - IC-F70D
Old 04-07-2009, 12:03 AM
I'm glad you have the ability to read/write the radio!
I constantly get "no answer from Transciever". Been all over the web trying to find information, but I can't seem to find any. Anyone got some pointers?!
Old 04-07-2009, 10:20 PM
N2DLX's Avatar
kc8svs,
Try holding down the P0 button while turning the radio on, then try reading the radio. This disables anything tying up the radio's serial interface (shared with programming) that interferes with the software. Until you disable anything using the serial interface (like GPS, Printer, PC Command), the radio will have to be powered up with the P0 button to read or write each time.
