Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Forum
ICOM Forum Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios and IDAS technology.
Old 06-22-2009, 07:51 AM
Alloy's Avatar
Default Need help Programming an IC-F621-TR
Bought one off ebay and am unable to get the radio to sync up to either of my computers for programming. I get a no response from receiver error message. Usinga legal copy of the CS-500 software v2. I contacted the seller and he stated that the radio was locked to his system and that I had to take it to a dealer. Don't relish the idea of spending $80 just to get it "unlocked" Any ideas? Thanks all!
Old 06-24-2009, 03:47 AM
N2DLX's Avatar
Send a message via AIM to N2DLX
Try writing a blank file to the radio instead of reading from it. Generally you can program the radio with a password which prevents the contents from being read. This lets you protect your frequencies and PL tones from anyone who ends up with a radio and may grab this info. The workaround is usually as simple as writing to the radio instead of trying to read the "locked" data.
Old 06-25-2009, 11:01 PM
Wrong software. The 621TR uses its own unique software package, which is NOT the F520/620 package.
I know, I work on those. My shop sells them. I had to check out one just two days ago.
Elroy
Old 06-25-2009, 11:09 PM
N2DLX's Avatar
Good eye, I didn't stop to check which software they're using. I assumed the most likely explanation was that there was a programming password in the radio.
Old 06-26-2009, 10:58 PM
w5gm's Avatar
Elroy
What is the part number of the software?
Old 06-30-2009, 09:20 AM
rgrat1618's Avatar
The cloning software is CS-F620TR v1.4.
Old 07-03-2009, 08:08 PM
Alloy's Avatar
I also have the f620tr software ver 1.2. I get an error message stating that this is not a compatible model of radio. The radio firmware version is 1.5. I took it to a shop that connected it up with their 1.3 version of the software and it worked perfectly. So i'm at a loss. Either my 1.2 version is not compatible and I have to get ver 1.3 or higher, or the USB cable I'm using is crap. I'm assuming the cable I'm using is ok as I don't think I would have rec'd the error message about a incompatible radio. Can anyone send me a a copy of the ver 1.3 or higher for evalutaion purposes? Please?
Old 07-06-2009, 10:58 AM
rgrat1618's Avatar
Alloy,
Send me your email and I'll get itover to you as soon as I get back to my shop.
Old 07-06-2009, 10:43 PM
Alloy's Avatar
Thanks much!!!
Similar Threads
FS: Scanner Programming zephyrshockey8 Old Classifieds Archives 0 06-08-2009 10:36 PM
Problems Programming BC396XT TBerry Uniden Scanners 13 05-07-2009 11:54 AM
Kenwood TK-790 Programming Cable ECHO3 Old Classifieds Archives 8 09-20-2007 06:19 AM
Programming software to control a scanner Gilligan Scanner Programming Software 5 01-19-2006 11:24 PM
