Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Forum
ICOM Forum Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios and IDAS technology.
Old 06-29-2009, 07:25 PM
1150RT-P's Avatar
Default Icom IC-A22 power / battery question
I have a A22 for use as a backup in-flight. I seem to have lost/misplaced the charger that came with it. I'm looking for another charger OEM to purchase for it.
In the mean time .... I noticed the AC charger for my laptop fits and powers the A22 (before freaking out ..... it turned it on under AC power for less than a second.)
Can someone who knows something about battery charging / power let me know if it is safe to charge the radio with this charger, or what information I would need to see if safe?
Thanks in advance .
Old 06-29-2009, 10:27 PM
Send a message via AIM to fineshot1
Thanks in advance .
You did not supply enough info for anyone to answer your question.
According to the A22 owners manual the supplied wall charger is a BM-112U
and it is supposed to be plugged in for charging for about 15 hours but for some
strange reason the manual does not state the specs on this wall charger so I
have no idea what the voltage/current specs are on it.
We would also need to know the specs on this laptop charger which you failed to
mention.
fineshot1
NJ USA
Old 06-29-2009, 11:12 PM
1150RT-P's Avatar
I am not very well versed on power supplies, which is why i'm asking for help, and i appreciate the quick reply.
Laptop Charger:
input: 100-200V ~ 1.9A 50/60Hz
output: 16V --- 4.5A
The only info i can find on the unit:
Ni-CD Battery Pack
CM-166
12V 600mAh
thanks again.
Old 06-30-2009, 01:09 AM
I found a reference on the internet saying that the BM-112U is rated at 12VDC 300mA
That 300 mA (milliamps) translates to 0.3A (amps) and your laptop PS is overkill at the 4.5 Amps. The A22 is spec'ed at 12-15Vdc maximum so the 16Vdc is also over that limit.
Best to stick to the original equipment as the charging time will be determined by that original wall transformer and the current rating of it (not overheating the batteries in the process). If you upgraded the transceivers battery to a higher capacity that may change (increase) the charge time of course.
Ed
Old 07-03-2009, 10:51 PM
1150RT-P's Avatar
Thanks. Time to track down another charger.
Old 07-04-2009, 06:38 AM
In the past I have acquired some on ebay and some for other icom radios will work
but you must make sure the plug type and DC voltage polarity is the same or be
willing to install the correct size plug.
fineshot1
NJ USA
Similar Threads
FS: Icom IC 746 Pro $925 Shipped kc2bnx Old Classifieds Archives 1 04-08-2009 02:54 PM
FS: NIB ICOM AD-55A 110 VAC 1.5 Amp Power Supply dixieboyfl Old Classifieds Archives 2 03-02-2009 01:21 PM
FS: Icom IC R-75 Shortwave Receiver icemantim8 Old Classifieds Archives 11 09-14-2008 10:56 PM
ICOM IC-R71A Power Cord Thunderbolt ICOM Receivers 9 02-25-2006 07:15 PM
Icom America Wins Large U.S. Army Order for New Radios n9nwo General Scanning Forum 8 05-02-2005 12:00 AM
