Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Forum
ICOM Forum Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios and IDAS technology.
Old 09-14-2009, 07:38 PM
Default F-11 programming/no audio
I programmed my F-11 to the frequencies I desired, but I can not get any audio or any indication that the repeater system I am using, is getting any signal from the handheld. I have programmed simplex channels on known busy frequencies to no avail. I even got desperate to see what was wrong and programmed the radio for NOAA channels, in which it will no receive audio from them as well. My question is, what exactly am I programming in CS-F11 incorrectly to make the radio not work?
Old 09-15-2009, 09:21 PM
rescuecomm's Avatar
It would help if you would list one full horizontal line of data from your CS-11 file. Some things to mind would be setting the two tone decode active on all channels or wrong CTCSS/DTS. The green light on top of the radio should be on if a signal is being received on the Wx frequencies.
Bob
Extra Class Op.
Gmrs Repeater user
Easley, SC
Old 09-15-2009, 09:53 PM
RADIOGUY2002's Avatar
Send a message via AIM to RADIOGUY2002
Default sCREEN SHOT
Give us a screen shot or a file to look over.....
Thanks, Ryan. Seller of Icom & Kenwood Radios
GMRS=WQHR752
Icom and Vertex Equipment=F5061/F6061-5, F43/33-4, F3161/4161T-2, FR3000-1, VXR-7000(U)
Uniden=BC-396T & 996T
Old 09-20-2009, 01:59 PM
RapidShare Webhosting + Webspace
I just tested with my ft-8900r that works. The f-11 is transmitting but when I try to transmit back on the yaesu I get no audio. I figured that it was probably a tone mis match to I programmed both the F-11 and the 8900r for 155.000 no tones. F-11 would transmit but not receive.
Old 09-20-2009, 06:17 PM
Default aTTACH IMAGE OF SCREEN SHOT
Attach image of screen shot, you could have miss a simple step. Find prtsc and duplicated the images in the art format, etc and then post images.
GMRS=WQHR752
Old 09-20-2009, 06:36 PM
Default check these settings out
GMRS=WQHR752
Old 09-21-2009, 11:19 AM
Attached is the screenshot of the programming info.
Old 09-21-2009, 05:56 PM
bezking's Avatar
Moderator and DB Admin
Send a message via AIM to bezking
Assign one of the buttons to "MONI." Hold it down and see if you hear static.
Nothing looks funny about your programming based on that screenshot.
--bezking
Moderator, NY-NJ DBA, Wiki Admin
bezking @ radioreference.com
Old 09-21-2009, 06:52 PM
rescuecomm's Avatar
You might try a speaker mic on the radio just to see if the face mounted speaker has opened up.
Bob
Extra Class Op.
Gmrs Repeater user
Easley, SC
Old 09-21-2009, 11:37 PM
Looks good, I try a 3.5 mm computer speaker first. But, he not even getting the green light. Any warranties?
GMRS=WQHR752
Old 09-22-2009, 01:48 PM
I just bought it a week ago from a known good online retailer. He has me rma it back.
Old 09-22-2009, 11:49 PM
Cool, as long as its gets replaced or fixed. It seemed like your problem was one in million type thing.
GMRS=WQHR752
Old 09-23-2009, 07:47 PM
RF connector failures are not uncommon on those radios. Quite often it's just a broken solder joing where the RF connector pin meets the circuit board. Easily fixed by retightening the screws that hold the RF connector into the frame (Loctite on those screws is HIGHLY recommended) and resoldering the connection on the circuit board.
I deal with those radios very frequently.
Elroy
Old 09-23-2009, 10:47 PM
Default RF issue
Elroy, he sent back to the shop. But, I to have seen the rf issue happen before as well. Damm RF... ugh the nightmare of my life.
GMRS=WQHR752
