Go Back   The RadioReference.com Forums > Commercial and Professional Radio > ICOM Forum
ICOM Forum Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios and IDAS technology.
Old 03-10-2008, 03:02 PM
Default Programming Icom F70
Anyone know how to get the radio into programming mode? Directions say that it is to hold F0 while powering on radio, not working. Using USB cable, drivers installed, tried all different com ports. Radio appears to briefly connect, comes up with the reading screen, then says unable to read.
Any Ideas?
Old 04-06-2009, 07:58 PM
Having exact same issue!!! Installed USB to serial drivers, and the whole shin-dig.
Someone needs to chime in on this year old problem.
Old 04-07-2009, 12:39 AM
What operating system/software are you using.
I had major issues with my 64 bit Sony Vista laptop, but installed VMWare, and running XP in a "virtual PC" solved my problems with the UHF F60 and OPC-966U software/USB cable.
ICOM's reply to my question about a 64bit driver wasn't encouraging.
The IC-92AD/RS-92 software works fine under Vista 64bit with a serial-USB cable adapter.
I may need to get the F60 serial cable (instead of the USB one) to use the software with Vista
First, check device manager to see what isn't loaded with proper drivers.
Old 10-28-2009, 09:11 PM
I solved the problem and never followed up. There is an option to make the radio read-only. The dealer of our radios had done this. With icoms, however, you do not need to read the codeplug and write it back. you can just simply reprogram it from scratch.
Had: Midland CB, M HT-750 VHF, Feidaxin FD-150 VHF, Midland 70-340A VHF, M Spectra VHF Dash, M P1225 Radius UHF, M MTX850, M HT-1000, M MTX 8000 B7, M MTX-8000 B5, ICOM F70DS - Duty
Similar Threads
Programming ICOM radios gg750 ICOM Forum 65 10-09-2009 03:10 AM
FS Icom R5 w/ programming software and cables safetyobc Old Classifieds Archives 2 12-27-2007 05:39 PM
FS: Icom IC-V82, programming cable and software... tbnmaster Old Classifieds Archives 6 12-19-2007 08:03 AM
ICOM F3GS Programming near DeKalb County, IL lawfarm ICOM Receivers 1 02-25-2007 01:25 PM
Icom America Wins Large U.S. Army Order for New Radios n9nwo General Scanning Forum 8 05-02-2005 12:00 AM
